Author Topic: 6watts and 8 liters HHO per minute...........  (Read 44202 times)
0 Members and 21 Guests are viewing this topic.
« Reply #280 on: February 16, 2021, 20:55:41 pm »
yes, i still cannot let it go.....
Here are two schematics that are additional to eachother.
I think that the toroid is getting its voltage of two ignitioncoils.
Then you get the tesla coil and the rest...
« Reply #281 on: February 26, 2021, 18:00:39 pm »
Nobody?
« Reply #282 on: February 27, 2021, 17:54:13 pm »
Nobody?
That's an amazing circuit, in it's simplicity.  Thanks for posting it; I guarantee I'm going to use it for something.  And I have spent some amount of time wondering how to wire up anti-parallel transformers.  What's the advantage of doing that?  EMI filter, so the MOSFET can keep it's smoke?
« Reply #283 on: February 27, 2021, 18:25:48 pm »
You simply create double the voltage.
With 20kv coils you get 40kv....
In the case of a Meyer, i might even decouple the secondairys, so you have a totally isolated secondairy circuit.
I know it is possible, but you have yo open the coil casings...
Its a bit of tinkering..
« Reply #284 on: February 28, 2021, 23:45:33 pm »
Moving ahead with this circuit, I ordered a hand full of N channel semiconductors.  The ones my supplier had on sale are 200 V @ 20 Amps.  So I may try paralleling 2 or 3.  Or I can try using a current limiting capacitor on the input to the coils.  Or even use a single ignition coil.
Also, a MOT takes quite a bit less than 20 Amps, so I can use the circuit to provide a high frequency environment for the Radiant Energy spark circuit I recently posted.
And I have opened an ignition coil casing before, to remove the core.  The hard part was keeping it from leaking afterwards.
And, of course, I always have a variety of other projects I can work on while I'm waiting for the shipment.
