Author Topic: 6watts and 8 liters HHO per minute...........  (Read 43975 times)
« Reply #184 on: December 05, 2018, 04:31:00 am »
nothing new
where is the effect? what is the effect? how much water you break per minute?
voltage? amps.. what is your cell...
everything you said we all individually already done..
« Reply #185 on: December 05, 2018, 04:44:21 am »
« Reply #186 on: December 05, 2018, 05:21:10 am »
well i agree with this idea... we actually were discussing about it... about having dc and pulsed dc over it but with an oposite bang to break the bonds .. i talked a lot and had no opportunity to finish yet..
you are electrical engineer too ?
« Reply #187 on: December 05, 2018, 05:30:53 am »
I used this method to charge and maintain a charge on my cell and afterward remove the power to it and it then continued to produce gas without power.  I did this 8 or 9 years ago.  I have a video showing it.  At the time I didn't realize what I had.  I don't remember offhand, although I say it in the video, but I think it kept making gas for more than an hour or two.... maybe even longer.
I have an engineer's brain.
« Last Edit: December 05, 2018, 14:11:02 pm by timeshell »
« Reply #188 on: December 05, 2018, 14:21:40 pm »
what you mean remove power? for how long it generated? vigorously?
how much power? what cell size? material?
i would love to see it ...where is the video?
« Reply #189 on: December 05, 2018, 14:39:33 pm »
I don't remember how long, but it was long enough to be a significant result.  It wasn't a mind blowing amount of gas, but it was very obvious that it was still being generated even though the electricity was turned off.  At that time, I was using a single cell, the inner pipe being 2" long, the outer pipe being 1" long.  314L with 304, don't remember which was which, but I think the inner tube was the 304.
At the time, I was theorizing the need for a continuous low voltage to be kept on the cell to keep the water molecules aligned.  I tried this a few ways and I don't remember the specific way I had done it.  But obviously it had a result.  I wrote about it before here at IonizationX.  At that time I called it priming the cell.  The idea was it needed an initial low, continuous charge to align the water just like an older water pump may need to be primed to work for the first time.  As Ronnie stated in the link I posted above, this is necessary in order to charge the cell.
He said:
You never want the voltage to fall below this voltage because it sets up the polarization process and low gas production and it can never be lost. As you can see this is a constant pulse voltage with no gating at all.
I'm trying to find the video.  I watched it a few months ago, but right now I don't remember where it is.  I will post it as soon as I find it.
« Last Edit: December 05, 2018, 21:13:50 pm by timeshell »
« Reply #190 on: December 05, 2018, 21:59:43 pm »
Timeshell I still dont understand that part of two cores where primary is in different core than secondary... The choke coupled to the primary will be basically a secondary and the supposed secondary the real choke...
Damn, this is confusing...
« Reply #191 on: December 05, 2018, 22:35:24 pm »
Yah, I hear you there...thing is, it works.  So, I wouldn't spend too much time worrying about it.
That's not to say it wouldn't work another way however.  The important thing is that the coils are properly designed for the corresponding reactances with the WFC for the desired frequency range.
« Last Edit: December 06, 2018, 00:42:21 am by timeshell »
