Author Topic: 6watts and 8 liters HHO per minute...........  (Read 43970 times)
« Reply #272 on: May 14, 2019, 22:48:09 pm »
Ok, this one was still on my to do list.
Here a picture of my testcell showing gas.
A note: it is charged, only by bemf.
I use the primary of an ignitioncoil.
« Reply #273 on: May 14, 2019, 23:04:19 pm »
Hello Steve.
Nice to see you're still working on it.
I am also working on my cell, but in a different prespective.
Cheers
« Reply #274 on: May 14, 2019, 23:45:27 pm »
If i find some time tomorrow, i will build the EEC part.
I think a P channel switch should be able to do that.
When the coil is charged, i also have to discharge the cell with the EEC circuit...however it will look like.
When the coil is discharging it self into the cell, the eec must be switched off.
It will be interesting to see if removing the charge of the cell, trully boost gas production...
« Reply #275 on: May 15, 2019, 18:00:55 pm »
well, i had the eec running.
A lightbulb was burning.
No special results to mention on that.
So i played a bit futher...
And then this happend..
https://youtu.be/KoKI1Slxui4
« Reply #276 on: May 16, 2019, 03:08:39 am »
what you done there?
i kind of see this happening in the past but it was a cable that were not well contact with the electrode in my case..
« Reply #277 on: May 16, 2019, 08:27:24 am »
i simply squerewaved the cell.
The signal frequency is 3 hz.
The change in amps is way slower going up and down....
So wierd...
« Reply #278 on: May 19, 2019, 21:52:46 pm »
https://www.youtube.com/watch?v=U5aWH95xZGA
Sometimes you connect info .......
watch from 39:10
Puharich pulsed slow ...2 a 3 seconds per pulse
To flip protons.
Its very intresting
« Reply #279 on: June 18, 2020, 15:11:51 pm »
Dedicated to Nikola Tesla
All we need is a little more time
I attached the Main Pic from the Start of Thread  the Spark plug coils are tesla coils they collapse and
output a cold voltage from centres
NEVER STOP
https://www.hot-rod-usa.com/copy-of-h2-training-guide
