Author Topic: 6watts and 8 liters HHO per minute...........  (Read 43974 times)
« Reply #224 on: December 13, 2018, 04:27:21 am »
Make sure if you had your tube pair wet that you dry them well. If there is water between them still it can skew your reading.
https://youtu.be/afyFaLYQlPA
« Reply #225 on: December 13, 2018, 19:13:24 pm »
Timeshell, thank you for your effort to show us this.
But, should we trust in a 10 dollar meter ?
Do you have access to a more reliable meter such as a fluke or other trusted equipment?
This modules uses the LC combination for measurement, others uses the RC scheme for capacitance measuring.
My meter does not show any difference thats why I am asking you for it.
Cheers
« Reply #226 on: December 15, 2018, 05:41:56 am »
Cheers
May not mean much but its understandable i suppose  ...capacitance is measured with a current flow from possitive to negative right? IF the possitive is bigger in diameter ....ehh * f * it lol...check a factory electrolytic capacitor and reverse the leads or something and see if you get the same reading...sense x blade isnt getting different readings he needs another example than a wfc.
« Reply #227 on: December 15, 2018, 05:51:43 am »
An electrolytic capacitor might not have different size electrodes.  I'll try to demo my cap meter with a variety of caps soon.
« Reply #228 on: December 15, 2018, 18:43:19 pm »
Timeshell thank you for the time you spend to explain that.
In my point of view it does not matter to much, since the pulses "hitting" the cell are always unipolar according to Meyer description.
« Reply #229 on: December 15, 2018, 19:40:47 pm »
Yes and no.  Because of the diode, the current will primarily go in one direction.  However, because the WFC is between two coils, it will still resonate between them.  This is why the chokes must be precisely tuned.  You will not get the high voltage climb on a pure DC circuit without the AC resonance.
« Reply #230 on: December 15, 2018, 20:05:30 pm »
I dont thing so, it cannot resonate with the diode.
When terminates the pulse the coils colapse producing an unipolar pulse.
This is a simple DC resonant charging not an oscillator.
People who tested it can confirm what I am saying.
The fantasy of "resonance" of LC died a few years ago.
The only possible "resonance" is between each choke inductance/capacitance.
The "Ronnie Walkie-Talkie" has gone now.
« Reply #231 on: December 15, 2018, 20:21:11 pm »
Ok.  Keep doing it your way. Let me know when you get it working.
