Author Topic: 6watts and 8 liters HHO per minute...........  (Read 44065 times)
0 Members and 20 Guests are viewing this topic.
« Reply #264 on: December 24, 2018, 22:23:14 pm »
There will not be "resonating" the way most people thing it does.
It works on D.C. unipolar pulses not A.C.
« Reply #265 on: December 24, 2018, 22:33:33 pm »
The source of the pulses isn't really relevant.  Resonating is resonating.
I think we are arguing a non-issue here.   The VIC is unidirectional current because of the diode.
The question then becomes what is causing the resonating action.   Yes it is a resonating DC charging circuit.  There is a resonating action occuring.  So, what is causing it?  Resonating occurs because of opposing actions from inductors, resistors and capacitors.
So, what is causing this in the VIC?
« Reply #266 on: December 27, 2018, 16:38:44 pm »
Timeshell why dont you explain this with some images?
« Reply #267 on: December 27, 2018, 22:38:20 pm »
what causes the resonance is the right frequency because at this frequency the system is able to accumulate energy and amplify the voltage current because of that
even if we shot in one direction only the ions will oscillate with double frequency because when pulse terminates another pulse comes into play from the chokes
im starting to think that electrical resonance is not even the most important resonance to find
« Reply #268 on: December 27, 2018, 22:47:28 pm »
LC resonance is not the key for the high production, I dont believe if we can get a "magic" effect of low power and high yeild of gas.
This is not the voltage alone, there will be always current.
« Reply #269 on: December 28, 2018, 00:31:39 am »
I agree there may be some other resonance involved.. so far i´m inclined to believe that is related to the ppm value of electrolytes... meyer says is in the audio range from 0 to 10khz .. i think zero would be whenever its overdamped (low ppm or perhaps too high)
lc resonance however is also mentioned by meyer... but here is where the two come into play tuning
« Reply #270 on: December 28, 2018, 06:30:37 am »
Hi I have been going over a lot of old research that I did and the group that I was with, also some guy Russ has also uncovered somethings of importance, and he meet with some one that actually went an saw Myer be for he ministerially died. Then also some of the mystery around the dune buggy seems that it was not all that was shown, yes it was technically running on water. However the whole system also generated electrical power and some form of heat. What some of you see is only some of the whole system not all of it.
He was a cleaver man and done separate patents for each part but I believe and I am not the only one you have to put the whole puzzle together.
There is a resonant part played in the system, the group of rising pulse all together then a short break, that is the negative side cut off by the diode that is a pump up circuit.
The frequency is important, but not the way that you may normally think.
The L/R of the coil T plays a good part in this, generated circulating currents in a resonate circuit can be very high, and with the step up transformer to around, 1500V is also a key.
So in the circuit it states that the wire used was resistance wire in all of the coils.
Why? He generated 1500VAC the diode will halve that to 750V have wave peek when it finally gets there. If you wound the coils in normal winding copper wire, then the DC resistance would be very low in the region of  0.01to 0.0001  so using the L/R technically you could generate thousands of AMPS. That is if the frequency was very low at resonance to give the current rise time to reach 5time T. High Frequency means that it has buckles chance of getting even to one T, 63%of the max current for a coil. Example at resonance XL=XC so all that in in the circuit is the DC resistance, do the sum 750/0.01 = 75,000AMPS! And more 750/0.001 750,000. Now you can may be see why Stan used resistance wire to limit the current at resonance, even then the current that may be there would still in the coil at one T may still not reach the max either.  So now we have a circuit basically that is generating high voltage with stuff all current. To me even then in tap water or worse distilled water or deionized water it has all the minerals removed. You still will not break it down as with electrolysis. There is another possible way around the sonar frequencies, 1Ghz is one range,
 Sport fishing sonar  50, 120, 200, 455 kHz . The sonar transducer was originally directly touching the water, as then they had tremendous amount of power pushed into them. the problem was that the water all around the Transducer got hot just like a microwave does to your food. What happened with the concentration of the power in one spot water split, the hydrogen and oxygen then burnt in the water pocket around the transducer and blew it up. Now they are not is direct contact with the water. So what does that tell you Stan seems to be doing something similar? Or there is fine arcing between the plates or tubes, this would disassociate the water as an arc is above 3,000C
Sorry to rattle on but I hope you get something from it and re-look at you thinking.
Stan what not telling the whole story publically.
« Reply #271 on: December 28, 2018, 08:29:44 am »
I dont undestand why people imagine things that was not there...
