Author Topic: 6watts and 8 liters HHO per minute...........  (Read 44067 times)
0 Members and 20 Guests are viewing this topic.
« Reply #192 on: December 06, 2018, 04:40:17 am »
Could there be a chance Stan was ahead of Witricity with 2nd resonance technology or is it totally off base with that?
« Reply #193 on: December 06, 2018, 06:16:21 am »
look at this paper about high energetic events in water electrolys..
« Reply #194 on: December 06, 2018, 11:58:27 am »
what do you mean ? i didnt understood...
TS
if the gas generated was so small in your test, how can you tell us that it were indeed working?
ii already build some cells where it aparently was producing the gas still after the power was took out but after some minutes it was gone...
steve and i had lot of discussions about it while i was still living in europe...  at that time there was someone interested into the experiments we were running and they asked us about the gibbs free energy of the system we were working at
after some years i learned that sometimes can have a potential difference because the surface of the metal is somewhat different or is not the same composition... and it would force the generation of some gas to compensate...
i would really love to see the video with your effect to be able to understand if it was something we already see or if we should really dig into!
i hope you found something... what is just getting me worried is what you said about the low productivity
stan says that at 5khz it should convert galons of water with a 3inch cell
the closer i got to this was when in italy i applied unfiltered full wave  bridge rectified 220v to a pair of plates 10x20x4mm spaced like 8cm apart and it was able with 3 amps to evaporate 1 liter per hour... it was a very violent production with lot of steam but was hard to get the hydrogen to burn because of the water vapor.. between the plates there was a sponge from a microfone box  i was trying to use it to increase the resistance by reducing the water amount .. it was just tap water from italy (hard water)
  • Build it. Power it. Use it.
« Reply #195 on: December 06, 2018, 12:28:23 pm »
A successful theory of operation has to apply to both the gas processor as well as the water cell.  There aren't any electrolysis bubbles changing the capacitance of the gas processor stage, so that's not how Meyer's system works.
« Reply #196 on: December 06, 2018, 12:54:06 pm »
Fabio
1.  It wasn't a few minutes... It was hours.
2.  It wasn't just a trickle that slowed down over time but was constant.
3.  My outer pipe was shorter than the inner one.  Because of this, I'm pretty sure you could see new bubbles forming.
I'm hoping I show the voltmeter in the video... That would very nicely confirm what I'm telling you.  I've been looking all over for it, but can't seem to find it for some reason.  I found it by accident a few months ago, so I must have it in a place I've forgotten about.
At the time I made the video, I recorded specifically because I was seeing activities on the cell which I didn't see before.  I understand your skepticism.  I'm pretty sure you will change your mind when you see it.
« Reply #197 on: December 06, 2018, 19:59:53 pm »
Timeshell do you have the video?
« Reply #198 on: December 06, 2018, 20:45:35 pm »
Still looking for it.
« Reply #199 on: December 08, 2018, 22:52:31 pm »
Found it.  Keep in mind, I recorded this 10 years ago.  I don't mention it in the video, but I was likely using a dual charging method where I had a lower voltage superimposed by a higher voltage pulse; what I considered to be at the time "priming the cell".  Obviously my understanding was still limited at the time.  In the video, I say that it has been a couple minutes since I disconnected the power, but, as I mentioned before, I checked on the cell hours later and it was still producing gas.  I don't have a video showing this hours later however.  The reading on the voltmeter is interesting and I can't explain what's going on there as I'd expect a higher reading on the voltmeter with the amount of gas being produced in pure water.
Sorry it took so long.  It wasn't on any of my usual computers and I had to resort to recovering it from a dead drive using advanced recovery methods.
Anyway,  here it is:
https://youtu.be/x7r42hEmFrU
« Last Edit: December 08, 2018, 23:19:26 pm by timeshell »
