Author Topic: 6watts and 8 liters HHO per minute...........  (Read 44019 times)
« Reply #136 on: June 23, 2018, 13:36:29 pm »
Hello guys.
Interesting patent of the water generator you found!
I was reading it and it sounded very familiar.
look to the coils the way they are stacked and their position on the Hydrogen Gas Gun:
(https://s19.postimg.cc/e4ygpvyar/DSC_0027.jpg)
What a coincidence....
« Reply #137 on: June 23, 2018, 15:07:47 pm »
that guy made just like meyer did ... he did lots of patents with somewhat related technology and gave parameters thru them for the realization of the principal that is the wormhole magnetic generator... in this patent he gave the 14 awg and 0.020 inch detail also that he tune to 60hz using external coil and capacitor but he uses a variable metal sheet capacitor
other parameters for this equipment are spread over the other patents
there is another patent of him that i didnt found that is the electric wormhole generator that he mentions in one of the patents but i could not find it ...
« Reply #138 on: June 23, 2018, 15:43:28 pm »
i know what looks like but i dont really trusted the guy... he seems to know too much about everything so little hard to believe.. however is a good idea about the cathode insulation but it become a dbd could it be able to fracture the molecules? well the fracture cell says it can
what you think about this ?
12 years ago, he was a known figure in the OU world.
I just found it intresting that he also uses bemf pulses and eec circuit to create electricity.
The hho as a by product is a bonus.
To be honest, i dont care if he used an insulated kathode. If i am back home in 2 months, i will build two test cells which one has an insulated kathode and the othe one not.
Easy testing....
I want to see if i can get 100dc out at 1 amp....
That 100watts....
Even if it is pulsed.
I dont care too ! it appear to me that is only a matter of the capacitance you can get and voltage applied and frequency to get those amps and voltage at a load... it need to be 100Ohms
having the cathode insulated has two implications assuming he is talking about the negative electrode
the insulated part of the cell would get filled with positive charge water which remember me immediately the patent of meyer saying that  electrons will be ejected from the water bath.. basically as we charge the the delrin water will have positive from both sides
assuming that now we are talking about 20kv it will easily get lot of electrons out of water lets say we are forming H+ ions and charging the electrode with OH- ions
the limitation is only the capacitance
1 farad = 1 amp * 1 sec / 1 volt
meaning that if you apply 1 amps for one second it will increase the voltage by 1 or discharging 1 amp per second will decrease 1 volt of a 1 faraday capacitor
this mean that if you have a small cell you need a high frequency and voltage to get considerable amps ,, ok maybe is not what is needed,,
how ionizers work?
or how can we get away with the electrons?
the only two ways i see is having one diode connecting the circuit to ground letting electrons go but not return
and  boiling of the electrons in a filament or negative high voltage needle (case of no ground) (the ions formed will however go to ground some time )
this will create an imbalance of charge since when we try to discharge the capacitor and coil back to the cell it wont have the electrons that cannot come back and the ions will necessarily react with water as they will be forced out of the electrode by the coils reversing voltage
on next cycle the opposite happen liberating electrons? this adsorb ions OH- maybe ionized by ejection and maybe with  strong enough pulse is possible to get it totally fractured
« Reply #139 on: June 24, 2018, 03:59:45 am »
something just happen to occur to me
a  capacitor in series can be the same as an inductor in parallel !
both are high pass filters
both apply reverse voltage thru load on the discharge cycle..
Re: 6watts and 8 liters HHO per minute...........NPN and PNP
« Reply #140 on: June 24, 2018, 18:30:58 pm »
Hi folks,
Here another version of a schematic for this setup.
After a request, i made a schematic with an NPN and PNP switch. The coil could be the 8xa...
« Reply #141 on: June 27, 2018, 15:58:33 pm »
Here a schematic based in the dudes youtube film.
It is clear to me that he contradicts himself.
He says that he only used BEMF pulses, but in this schematic he also uses EMF.
Go have a look.
https://www.youtube.com/watch?v=xtZwXdyXsd0&feature=youtu.be
sergei
« Reply #142 on: August 02, 2018, 05:03:50 am »
https://www.youtube.com/watch?v=TqpU80kf3rg This man shows how to charge cap from 1,2V battery to 19V. Looks like with back EMF effect.
« Reply #143 on: August 02, 2018, 09:33:51 am »
thanks for posting.
It is known that you can charge a cap that way.
Ill guess the trick is to short the wfc after a charge...
So, not really step charging but discharging...
