Author Topic: WFC VIC  (Read 148090 times)
Re: WFC VIC
« Reply #80 on: December 07, 2010, 16:15:40 pm »
Green coil = feedback to PLL
Re: WFC VIC
« Reply #81 on: December 07, 2010, 16:18:57 pm »
Thanks Alan!
Re: WFC VIC
« Reply #82 on: December 07, 2010, 17:51:00 pm »
NP.
How can I measure the HV output of the VIC with my (yet to receive) scope safely with a voltage divider or HV probe, without blowing up my scope?
Re: WFC VIC
« Reply #83 on: December 07, 2010, 17:55:24 pm »
Well i don't have this answer, I had a scope and i burned it using a 1000:1 probe... the probe was rated at 40kv, maybe was my fault by having exceed a lot this voltage during the tests...
Re: WFC VIC
« Reply #84 on: December 07, 2010, 18:23:19 pm »
Damn, that sucks. Could you repair it?
Re: WFC VIC
« Reply #85 on: December 07, 2010, 18:49:53 pm »
I have found ferrite EE-cores, how are they clamped together?
Re: WFC VIC
« Reply #86 on: December 07, 2010, 21:19:03 pm »
not yet, i left it in italy...
you could use some tape or anyway you find easier.
Re: WFC VIC
« Reply #87 on: December 08, 2010, 00:54:57 am »
Alan,you can use a voltage divider.Get 10 each  1megaohm resistors and hook them up in series.Hook one end to the cell positive and the other end to ground.Then hook the scope probe between the 9th and 10th resistor.That would be closer to the ground end of the resistor dividers.This will give you a divide by 10 output to the scope.With a probe set on 10x and this divider,you'll get 100:1 ratio.
