Author Topic: WFC VIC  (Read 148084 times)
Re: WFC VIC
« Reply #112 on: February 19, 2011, 12:48:54 pm »
I would go for what stan said, oriented grain electrical steel laminations. This is made to work at high frequencies.
Otherwise you could use amorphous laminations witch is even better.
Re: WFC VIC
« Reply #113 on: February 20, 2011, 14:36:22 pm »
That's right Tony, also, the core is of ferromagnetic material and will act as a frequency doubler, so that should help in the 10kHz question using 5kHz as a base FR.
This paper appears in: PGMTT National Symposium Digest
Issue Date: May 1961
Digital Object Identifier:
10.1109/PGMTT.1961.1122355
Date of Current Version:        06 januari 2003
"In experiments on frequency doubling using ferrite slabs in a   rectangular wave guide, planar ferrites consistently had much greater   conversion efficiency than isotropic ferrites. The principle results are   shown in Fig. 1. The geometry used is also shown in Fig. 1. The primary   frequency was in the range of 8.5 to 9.1 kilomegacycles. The reference   power level (0 db) was one watt peak power. The duty cycle was 10-4. The material properties are given in the append
Re: WFC VIC
« Reply #114 on: February 20, 2011, 23:56:31 pm »
that photo above is a wound core with  blue  epoxy coating... nanocrystalline... they had a couple left from a batch that was just off spec... something tom bearden used for his MEG... at least thats what the chief of operations told me... i think they have a few of these left.
they were going to gap one for me because if we do it in a garage with a hacksaw the result will be shorted laminations and both halves need to be polished to a fine straight line across both halves so a hand saw would cut a crooked gap... wont work
also if the fine chips from the blade end up between the wound laminations the turns will short out then you need to put both ends in an acid bath to clean out the shorted turns.... very high tech cores !
Re: WFC VIC
« Reply #115 on: February 21, 2011, 23:18:45 pm »
Hi,
I'm new on this forum and just read through this topic. But some questions/comments arrived:
@Dynodon:
The core was two flat U cores about an 1/8 inch thick and about 1/2 wide
Jesus, was the core area really that small on this 5-Coil-VIC? Is that a screw in between the 2 choke coils on the pic, or is this the core? If it's the core, then from the picture it looks definitely gapped. This would be for me actually the only explanation, how a core with such a small core area could have been used without being saturated. Although if only a small current is flowing, with that many windings (from the pic and AWG size I would guess about 2'000 per bobbin), it would certainly saturate any ungapped Iron-powder or ferrite core. I would even have doubts if a steel core could handle it with such a small core area.
If it is an ungapped core, then the only conclusion I could draw is, that he intentionally let the core go into saturation.
Alan,you can use a voltage divider.Get 10 each  1megaohm resistors and hook them up in series.Hook one end to the cell positive and the other end to ground.Then hook the scope probe between the 9th and 10th resistor.That would be closer to the ground end of the resistor dividers.This will give you a divide by 10 output to the scope.With a probe set on 10x and this divider,you'll get 100:1 ratio.
Just a little correction. I think you accidently made here a mistake by saying only 1MOhm instead of 10, for at the beginning of the thread you explained it correctly. To get a 100:1 with a 10:1 probe you need 9x10MOhm resistors. That means actually a resistance of 90MOhms. Your 10:1 probe has internally a 9MOhm resistor. The oscilloscope has a 1Mohm input resistance. So you will now have in total 90MOhm from your resistors+9Mohm from your probe+1Mohm from the oscilloscope=Total of 100MOhm. As the scope has a 1MOhm input, it will see only 1/100 of the total voltage.
So again in a short version: You need to place 90MOhm (eg. 9pcs of 10MOhm resistors) in between your 10xprobe and the cell to measure at 100:1. VoilĂ !
Did you actually really exactly look, how the coils were interconnected, or is this just a guess. As I understand you say, they were all connected in series with the WFC in between all in the same orientation. This means: If the primary gets current, then: The pos side of the secondary goes to the diode. The pos side of the first choke coil goes to the WFC. The pos side of the second choke coil is again at the secondary.
Additional question, which I think could be important. Did you see, if he electrically isolated the circuit, or was it grounded. Was the neg side of the secondary anywhere connected except the second choke coil, or was there any other ground connection (E.g. was the diode in the 5-coil-VIC mounted with isolation)?
Additional question: Somewhere here in the forum you state, that the "8XA-Circuit" wasn't a resonance circuit. How did you get to this conclusion?
I don't want to offend you, but I think it actually is. If you simply connect and drive it in the way Stan did, you will clearly see, that at a certain frequency you will get a resonance.
(I attached a small pic of my scope which shows the resonance condition. Unfortunately I could only drive the circuit with 20Volts, as my frequency generator surely cannot output more. I also only made very few windings, therefore the resonance frequency is a bit high (25 KHz), but I think the basic principle remains the same.
If one does look at how he connected the choke coils in this "8XA-Circuit", it is obvious, that if he really connected them like that, then they surely do not limit current in any way, as they cancel each others field out and are only seen as a resistance by the input voltage. But due to the capacitance in the system (and I don't mean the WFC capacitance, as this capacitance is at least for this circuit almost completely neglectable), the system is able to start to resonate and the voltage of the coils rise.
(http://img198.imageshack.us/img198/5135/yellowonwfcbluefgsignal.gif)
Blue: Input Signal after the Diode
Yellow: Signal on WFC (first choke coil side)
Red: Voltage over first choke coil
If this is really how this "8XA-Circuit" worked. Then it would make sense, that he introduced the primary/secondary (in a forward converter usage) as a replacement for the direct connection of the input voltage. But if the 5-Coil-VIC really would also have worked on the same basic principle, then the choke coils would have been wired differently (namely the same way, as in the "8XA-Circuit"). Therefore my above question about the wiring and orientation. If you say, that the choke coils in the VIC you saw were definitely (100% sure) not connected like that (same polarity to WFC), then that's OK, but I just wanted to be sure about that.
I would be really grateful if you could shed some light on these points, as you are the only one I know, who actually really saw Stan's originals.
Just to mention: The most important factor, when it goes about laminated steel cores and frequency is lamination thickness. If you go by the frequencies here used, i would say, the laminations should be <= 0.25mm. And to get cores with such thin laminations is not that easy. Audio-Transformers usually have them, as they also operate at these frequencies.
« Last Edit: February 22, 2011, 14:12:05 pm by Kali_ma_Amar »
Re: WFC VIC
« Reply #116 on: February 22, 2011, 18:22:44 pm »
I'm planning to create an extreme version of the color-taped  VIC, using 38AWG (ex. coating size) for secondary and chokes and for the primary a thicker wire on a modified EI to UI core.
Turns:
Primary: 50-100
Secondary: 30k-40k
Chokes: 30k-40k
Ratio Pri:Sec for 50:30000 = 5:3000. input 12V -> 7,2KV
Never wound a coil before, but I definately won't do it by hand  ;D
Am researching the coating for the available wire atm (7KG 38awg bobbin)
any suggestions?
Re: WFC VIC
« Reply #117 on: February 22, 2011, 21:05:17 pm »
kali,
The cores for the vic coil were as stated.They did touch when put into coils.That's just a hole in the bobbin to see that the cores are together.The picture of the vic coil,the coil pack wasn't bolted down,so they may not have been touching.
As for the explanation of the 100:1 resistor divider you give makes sense and explains some things to me that I have seen in testing with mine.An electronics engineer gave me those numbers and a spice file showing a dived by ten using the 10 1meg ohm resistors.I measured my probe on 10x and it does measure 9meg.I will have to correct my resistor divider.Thanks for that info.
The coils were wired and hooked up just as I said.That info was taken directly from the vic coil.
The negative connection was isolated,not connected to any ground plane.And the diode was isolated mounted to coil case.
As for the plate cell resonating,I never saw it with a scope.Your test looks like you were driving the coil with a square wave only.The 8xa circuit drives the choke coil with a rectified ac wave and square waves.It gives a totally different output to the coils.You get unipolar humps with a frequency riding on top of it.Your wave is totally different.With my vic coil setup like Stans,I get the same waveform output that your scope shot shows.
Re: WFC VIC
« Reply #118 on: February 22, 2011, 21:42:48 pm »
First: Thank you very very much for your answers, really!
Could it be, that maybe he made the hole to be able to insert anything in there, so that the core gets a little gap?
For this is surely an important fact for me. If it was really ungapped, I would bet my left hand and right foot, that the core goes into saturation. This would actually mean, that suddenly all the resonance frequencies would drastically increase in the middle of every half-wave, which means the dU/dt values would rise a lot.
Actually if you test it, it doesn't really make any difference in this setup in relation to the resonance if you use a square wave or a rectified AC wave. You can see this very clearly if you modulate any wave pattern from the frequency generator with the overlaying on off timing. The only important thing would be to correctly time them on and off (namely at the resonance frequency). The kind of wave pattern you switch on and off is actually not really that important (although a square wave pattern can surely boost your resonance to the highest voltage, for obvious reasons). In this crude setup, which was surely one of his earlier ones, IMHO he just still needed the unfiltered rectified AC Signal to be able to switch it with a SCR.
At least this is the conclusion I drew, by experimenting with this early circuit setup.
Surely this is only true in relation to getting the resonance (the coil part). The actual wave-pattern itself is additionally seen directly by the resistance of the WFC. If it then makes a difference in the overall functioning , I don't know, but I don't think so. But as long as not anyone is really able to replicate a working VIC, which yields more hydrogen than it should, IMHO everyone is allowed to have his theory, as how exactly these circuits split water more effectively than "generally allowed" ;) .
I personally would currently have 2 main suggestions how he did split the water:
1.) He used the uneven E-Field distribution in a water cell (Helmholtz-Layer) to get the necessary high E-field for splitting water. The needed E-Field is quite high. According to the Tay-Hee Han patent (US patent 4427512) at least an E-field of 20kV/mm is needed. IMHO he manipulated the Helmholtz-Layer with the help of the "choke coils" in a basic circuit very similar to Dr. Stifflers circuit.
2.) He used a system, as described by the professor in the evaluation report. Namely, that he does let the normal brownian movement do the work to ionize the water, and then separates these ions from each other with the help of an E-field. If he then neutralizes them again (collapsing of the E-Field), you will have an electrolysis which is much more efficient than usual, as the additional energy is coming from the heat energy of the water. But if this system was used, then the WFC should have substantially dropped in temperature. In the smaller 3inch cells, it would have frozen the water, if it would not have been continuously run through the cell to prevent this. But as this is not the case, as I understood Stan, this hypothesis is not that solid.
« Last Edit: February 22, 2011, 22:30:04 pm by Kali_ma_Amar »
Re: WFC VIC
« Reply #119 on: February 23, 2011, 00:32:55 am »
I can not see there being any gap in the cores once the coils are bolted to the case.The end caps on the coil pack has to be squeezed in on the U cores in order to bolt the assembly down.At that point there is no gap.
Here's a picture of the pulses at the cell from the 8xa circuit.This should help you see what I'm talking about.
