Author Topic: WFC VIC  (Read 148093 times)
Re: WFC VIC
« Reply #360 on: April 23, 2011, 05:10:55 am »
@DON
seems like the Q8 on VIC CARD was an after thought, even though the fingers go out to an external Q8
What gives?
Here is the updated figure 4 schematic based on the Vic Card details
Re: WFC VIC
« Reply #361 on: April 24, 2011, 18:51:19 pm »
I was looking at core materials, and the iron powder core are an interesting material, but initially got a low permeability - I for one think that this is important as inductance is, and iron powder cores do have an upper limit there. Quit often permeability in iron powder core is less then 100 in PM, these cores contain other interesting aspects, but PM and induction is important, so I located a ferrite material that might have potential, so please take a look at it and comment.
*Ferrite Material 78 (soft ferrite) meaning it can be machined!!!
  Initial permeability is between 2300-2500
http://www.fair-rite.com/newfair/materials78.htm
Re: WFC VIC
« Reply #362 on: April 28, 2011, 00:21:13 am »
I would avoid the toroid co`s its not in the his vic matrix patent, probably best to use the later patents. The stainless wire looks like it is used with his injectors so avoiding them will save u a lot of hassle. Read the vic patent and learn the different technologys he talks of (vic and vec) as he flips between them almost in the same sentence, this makes reading his patents easier, i think the vic is a simplier build. His vic is reasonably well described except the primary coil, he said the primary is bi-directional wrap...bi is 2, 2 directions and wrap means wrapped around the former. The bi-directional is one half of the transformer primary is wound in one direction and the other half is then wound in the opposite direction forming 2 coils of opposing magnetic fields, this is wound longitudal to the chokes and secondary,i am 98% certain that is exactly how it is wound. Another tip would be if u put a resistor in miss out the voltage multiplier coil for now but not the electron inhibitor coil, you can make it a variable resistor for easy adjustment.
I have had this producing gas but there is some sort of "tuneing" needed i cannot work out at the moment, but haveing gas production with uA`s flowing out of my mini vic shows it can be done.
(this post came from Joe2 at http://www.energeticforum.com/renewable-energy/7765-hho-production-stan-meyer-style.html)
Re: WFC VIC
« Reply #363 on: April 29, 2011, 11:49:22 am »
This is what I'm seeing in the circuit...is this what you guys are seeing???
(http://www.globalkast.com/images/tonywoodside/PLL&CellDriver.PNG)
Hi Tony
What is the value for the capacitor near the 22k resistor?
hm
Re: WFC VIC
« Reply #364 on: May 01, 2011, 03:41:50 am »
Can someone explain to me why the cell driver circuit uses 4 transistors instead of only 1?
Is it just used to amplify the signal so the tip120 has full conduction?
« Last Edit: May 01, 2011, 04:11:01 am by HMS-776 »
Re: WFC VIC
« Reply #365 on: May 03, 2011, 20:48:26 pm »
just thought i would show off my new board ;-)
(http://i82.photobucket.com/albums/j243/outlawstc/water%20fuel%20tech/101_2019.jpg)
    • Stan's Dream
Re: WFC VIC
« Reply #366 on: May 03, 2011, 21:53:41 pm »
Wow, looks like someone else has been busy too!
My parts are still coming in!
Re: WFC VIC
« Reply #367 on: May 06, 2011, 06:18:09 am »
Outlaw, what program did you use to design your board?
