Author Topic: WFC VIC  (Read 148203 times)
Re: WFC VIC
« Reply #408 on: February 06, 2012, 05:05:16 am »
There is conflicting information floating around - since no one has been able to get the dunebuggy version of the vic to do anything, it makes me wonder:
Artinvegas says Stan had the coils made from stainless steel wire he had epoxy coated at a company in NC.
Don says the wire was copper magnet wire, AWG29.
Who is right and who is wrong? Did Don physically disassemble the coils to verify they were only copper?
Also, what kind of core was used - did Stan make his own?
It seems there would be a supplier somewhere.
I simply do not see how such a small number of turns could make KV output.
All my tests show very low voltage out, certainly not KV.
Are we all chasing a pipedream with this? Perhaps when Stan's stuff was confiscated, these vics were planted byt the MIB to throw people off, as they did with the rotary vic motor?
A lot to think about...
Re: WFC VIC
« Reply #409 on: February 06, 2012, 05:22:40 am »
The 5 coil VIC transformer was all copper wire...the 6-1 (Tri-Coil) transformer used both copper and 430FR SS wire. In the 6-1 coil, Stan used the SS wire for the chokes for many reasons....1) To create electron clustering between the secondary and chokes. 2) Prevent signal "ringing". 3) Create a resistance to restrict current due to the high voltage (approx. 40kv). 4) The SS wire will produce a much stronger magnetic field than copper wire.
The core for the 5 coil VIC transformer was made of Ferrite with a permeability approx. 1000 - 1500. The 6-1 transformer M27 steel laminates.
From testing that I've done with my replication of the 5 coil VIC, I've gotten over 2kv out of it and its a 7:1 step-up. I also tested a 1/2 scale 6-1 coil and I've gotten over 4kv out of it.
Re: WFC VIC
« Reply #410 on: February 06, 2012, 09:59:41 am »
you mean across the water or across a simple capacitor?
Re: WFC VIC
« Reply #411 on: February 06, 2012, 12:32:33 pm »
across an actual capacitor based on the calculated value of the cell's capacitance. Still working on getting a resonant cavity made.
Re: WFC VIC
« Reply #412 on: February 06, 2012, 20:17:40 pm »
hy tony,i listened the radio interviu-Jeff Rense show and ''JW'' said that he will put some videos and doc's on jeff's site,but can not enter the arhives..must pay to register,do you know what is this docs about?
by the way nice site you have!
Re: WFC VIC
« Reply #413 on: February 07, 2012, 00:44:49 am »
dont forget the resistive element custom made on the negative side of the wfc...
maybe a huge wattage 10 megohm pot would be a start
Re: WFC VIC
« Reply #414 on: February 07, 2012, 08:28:21 am »
you mean ten 3" tubes in series with a calculated cpacitance of around 877nF ?
Re: WFC VIC
« Reply #415 on: February 07, 2012, 16:33:57 pm »
I asked Steve Meyer about that very issue, the series connected cells...he replied "there were many different configurations being tried, that just happens to be one of them..."
