Author Topic: WFC VIC  (Read 148088 times)
Re: WFC VIC
« Reply #352 on: April 19, 2011, 14:51:59 pm »
Anyone have a clue about this?
(http://i82.photobucket.com/albums/j243/outlawstc/water%20fuel%20tech/4046.jpg)
Re: WFC VIC
« Reply #353 on: April 19, 2011, 20:03:05 pm »
continue line down below the question mark and connect to pin 14 of 4001 to the right
(maybe)...
Re: WFC VIC
« Reply #354 on: April 20, 2011, 01:29:17 am »
Newguy, Q4 is a 2N3055 and Q5 is a TIP120.
Outlawstc,that wire comes from pin 3 of the PLL and the connection going to the tab at the base of the card doesn't hook to anything,it dead ends there.So it doesn't matter whare it goes.
Re: WFC VIC
« Reply #355 on: April 20, 2011, 11:01:00 am »
Thank You Dynodon   8)   looking forward to getin parts n stuff  :)
Re: WFC VIC
« Reply #356 on: April 20, 2011, 16:05:36 pm »
Thanks Don that one has been on my mind for a while..  I'm also curious to where the ANL/FREQ switch is connected and its function in the circuit... it looks to me like one of the wires is going to one of the switch 2 pads on the board..
If i were to guess what it is for i would say its to switch the bnc test output to send out 1 of 2 signals.. Either the variable amplitude or the cell drivers  output.. allowing one bnc connection to be easily switched between 2 signals?
Re: WFC VIC
« Reply #357 on: April 21, 2011, 00:06:24 am »
outlawstc,your exactly right on the anl/freq switch.It lets you see the cell driver frequency or the analog voltage output.
Re: WFC VIC
« Reply #358 on: April 22, 2011, 10:51:28 am »
Don, parts Q1,2,and 3 on figure 3....  those would help alot as well.
Re: WFC VIC
« Reply #359 on: April 23, 2011, 04:55:34 am »
Here are some work intensive photo edits of where i think the traces go on the VIC Card
frontplane is blue, backplane is red
start by tracing power routing to every chip to verify.
also seems to me that pin 3 of the pll goes to the 10k resistor called point "G", the input of figure 5.
(because pin 4 of PLL- VCO signal out, goes to pin 14 of 4017, pin 14 is the clock input and i would suspect that according to the photo and according to the figure 7 schematic this would be true)
Basically signal goes out on pin 4 and comes back on pin 3 so if you switch in one of the 4017s the frequency is divided and comes back from pin12 carry to pin 3 pll and at this point goes to point "G"
if pll pin 4 went to point "G" the 4017 dividers wouldnt work...
also here is the multisim simulation for figures 3, 4 voltage circuit... still have to test it in the real world but its updated based on the VIC CARD revelations...
