Author Topic: WFC VIC  (Read 148202 times)
Re: WFC VIC
« Reply #304 on: March 23, 2011, 10:11:45 am »
Yes that`s it Tony.
The blue wire overlap was a bit tricky there.
This makes much more sense now!
Please discard my previous posts.
Any ideas of what capacitor values should we use?
HM
Re: WFC VIC
« Reply #305 on: March 23, 2011, 21:09:25 pm »
I've edited your schematic and added the pin numbers.
(http://www.globalkast.com/images/stanmeyer/wo92-6.jpg)
SN74123 would work because pins 1&2 are connected only one "A" input is required and pins 3&4 would be the single "B" input and pin 9 internal resistor is not used here so 74122 is not as good as 74123...
Re: WFC VIC
« Reply #306 on: March 25, 2011, 01:36:45 am »
figure 4 seems to have 4 op amps installed on the VIC CARD instead of 3, that leads me to believe that figure 3 was located elsewhere, on another controller...here is a multisim circuit of whats on the VIC CARD...exactly (almost) like the circuit on FIGURE 4 sheet.
Re: WFC VIC
« Reply #307 on: March 25, 2011, 08:24:36 am »
Hi ali,
can you please post the file in multisim version 10 format ?
hm
Re: WFC VIC
« Reply #308 on: March 27, 2011, 22:40:06 pm »
Hi ali,
hm
Dont have the capability as im using the evaluation version, student edition ms11
sorry
Re: WFC VIC
« Reply #309 on: March 29, 2011, 07:25:48 am »
well my wire came in today so I successfully wrapped one choke by hand and it took me about 3 hrs to do...very tiring to do lol...but its with in range of Don's resistance measurements. It's 3,000 wraps and has a resistance of 75.5 Ohms. I compared it to Stan's VIC and it matches up perfect in size. Here's a picture of it.
(http://www.globalkast.com/images/tonywoodside/My_VIC_1-2.jpg)
Re: WFC VIC
« Reply #310 on: March 29, 2011, 09:42:37 am »
HI Tony
You can use hand drill to wrap the coils. Simply attach your bobbin in head drill and run drill by hand.
andy
Re: WFC VIC
« Reply #311 on: March 29, 2011, 15:15:49 pm »
Its one the the jobs i hate to do as well......
Looks good!
