Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 190259 times)
« Reply #512 on: December 02, 2013, 20:18:45 pm »
Thanks Brian!i know how it was hooked up,bat>inverter>motor>alternator>cell
So he just restricted the amps to the cell...Which pdf?the one with a pulsed rotor with 555?
« Reply #513 on: December 03, 2013, 01:49:00 am »
No. Theres no restriction of amps. Watergas is synthetic and acheived at sjperheafed temperatures. Hydrogen contamination of this steam gas confirms synthetic. See my videos youtube name thebriancoats.
« Reply #514 on: December 03, 2013, 01:56:05 am »
The alfernator is a toy in your above post. Stan used a factory. High current alternator to power the 12v to 220v rotary converter today we use converfers with no moving parts connected to the oem algernator. The phase converter can be digital like stan later hid or rotary where it is the better choice. The alternater is a distraction but the point makes its way. My pdf is here. I cant find it on a 3 " phone.
« Reply #515 on: December 03, 2013, 11:18:08 am »
Brian,if he was using the inverter to power the cell,who powered the drive motor of the alternator?
« Reply #516 on: December 03, 2013, 17:56:25 pm »
The phase coverter powered the plates. Yhe rotary inverter powered the phase converter to gain a third leg. The oem alternator powered the entire system. There was resonance in that system protecting the alternator. Hydrogen was produced at a commercial rate on board that bug. The pwm and alternator presented is the great ideal for ahow n tail and was capable of a synthetic gas at a mim rate to display bug not revealing the maximum rate sys where petrol fumes was not used unlike the shown. Study phase con erter and build u one. U will be closer. This system is like a heat pump that drws energy from somewhere else just as the heat pump gains heat from 5 degree temperature to heat the home. The fuel cell resonates with the phase converter which feeds from the voltage inverter which feeds from the high current alternator.
« Reply #517 on: December 03, 2013, 21:22:01 pm »
oh man my head hurts,can you make a quik drawing of component interaction?
Starting to get it....you are refering at the drive motor as a ''rotary phase converter'' which generate 3phase 110v AC,then rectified and conected to cell, but also rotate the alternator which charged the batery.
But why convert 1 phase to 3phase?i understand 3 phase is more eficient than singe phase...
« Last Edit: December 03, 2013, 23:48:58 pm by adys15 »
« Reply #518 on: December 03, 2013, 23:38:00 pm »
Hi Adys,
What do you expect how the alternator should work?
I know for sure that the alternator setup was a high amp pump for a tube cell configuration. Nothing else. Nothing to do with low amps and high voltage.
My close friend held.his hands on the cables during.his visit at Stans place....
Hot. Hot.hot.
Your friend wasn't lying.
People just cant get it thru their heads that there is the CAPABILITY of current in the alternator, however it does not produce current.
The load produces current. Your load is the chokes, not the water.
 He used the alternator because he could change the frequency of the pulses to the resonant frequency of the cell, which resonates the chokes which shuts off the scr. Unlike using a variac where the frequency is locked in at 120hz.
Get it to not see the load. It is all timing, the parts you use and where you put them.
 Yes, it can switch that fast. It wont heat up much if your using 24" cells like he did. He had all the cells hooked together, Add up the gap distances and surface area and that is max voltage input.  In that configuration the cell will not heat unless it is run for hours at max voltage. Then you have to get rid of electrons.
« Reply #519 on: December 03, 2013, 23:51:12 pm »
Hardchrome,the chokes are inside the alternator,no scr here
