Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 190262 times)
« Reply #416 on: August 14, 2013, 21:35:32 pm »
Thanks komtek,i dont think thats the problem,i think the coils are wound wrong.I think there must be 1 wound clockwise and the next counterclockwise,i am refering to one phase only.I spent a week winding theese bobins and got 6v very frustrating....
« Reply #417 on: August 14, 2013, 21:58:23 pm »
yes if you wind all the same direction on a bobbin, tie each coil and pull the group off the bobbin.
When the coil is installed 1st loop goes up/over and second loop down/under like opening a spring.
I just use a piece of pvc pipe same size as loop and wind by hand.
« Reply #418 on: August 14, 2013, 22:31:12 pm »
thanks,i dont exacly what you mean by winding stile,can you make a quik drawing of the corect directions of each coil for one phase only?I use a ''sandwich''tipe former on my winding machine,and i dismentel the sandwich after each coil,very time consuming but the coils looks perfect.
« Reply #419 on: August 15, 2013, 02:26:14 am »
Look at page 15 and 16.
Follow the lead wire as it goes over then under.
« Reply #420 on: August 15, 2013, 11:43:19 am »
Thanks soooo much Komtek,thats gold,old school with drawings and skematics,very very nice.Now i have to get some wire,because that that i wound is scraped all over.Cheers!
« Reply #421 on: August 15, 2013, 21:03:31 pm »
What about this wiring style?i dont see it anywere
« Reply #422 on: August 16, 2013, 03:32:20 am »
That alternator/stator looks like 4 poles.
Have never wound like that, have you tested this wind?
I like it all filled up.
« Reply #423 on: August 16, 2013, 10:58:57 am »
I haven't try it.4 poles N ,4South i think,here the page
http://www.instructables.com/id/How-To-Rewind-an-Alternator/#step1
