Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 190250 times)
« Reply #368 on: June 24, 2011, 20:37:20 pm »
I don't want to convince anyone, I just raise the question, He clearly talk about messing around with electron resonance energy levels, there is only one way this can be done. Laser principle... He talks about ejecting electrons, out of the orbit, the only way you can have atoms to do this with no expense in energy, is to keep the energy there and than do whatever you want with the material...
I'm saying the cavity will have high energy accumulated, this is potential, (not consumed) when you transmute one molecule it will give off the energy to the others and so on...
I'm not sure how the electron ejection occurs this is hard to find, they only talk about the photons actions... But my best guess is that having the energy inside it will keep inside or would get into the atoms, however as we want to have destabilized atoms i see no problem. however i guess the energy will keep mostly inside the cavity, this will aid the process on other molecules... He says that he momentaneusly pluck off the electrons of the oxygen and when the atoms recombine with those electrons they get neutralized and released as gas... He than state when the gas atoms further suffer loss of electrons, they cause fisical impact cause they get deflected by the voltage fields witch is what he call Resonant action... probably xrays would be the best to induce this electron ejection... 13,6ev is not hard to achieve.. actually applying 13,6 volts over a filament will produce electrons with this energy... the  thing is to make this get into the cavity ...
Microwaves are not a big problem, they have low ev energy, So we could charge the water probably with visible light energy to get high energy state.
The number of photons we provide will be absorbed and than the water will in the end emit amplified microwave witch will remain enclosed into the cavity...
Just ideas...
« Reply #369 on: June 24, 2011, 21:22:03 pm »
well seb your posting what could be considered exotic ideas on a thread thats trying to focus on a specific process through the left behind works of stan.
It simply side tracks and confuses everyone trying to learn about  the rotory vic...  can we keep this thread based on stans documents about the rotory vic.. rather then theoretical ideas that are over complicating what stan says....
thats all i ask.. if you want to bring up somthing exotic from what stan describes feel free to do so on a new thread.. i just wanna keep this thread based on stans information provided in his patents.. so people who are trying to learn that have less of a understanding are not getting lost in your theorys of the process,,
« Reply #370 on: June 24, 2011, 21:56:29 pm »
ok, sure...
« Reply #371 on: June 25, 2011, 00:11:23 am »
I have a pretty large tube cell just sitting around! Looks like I need to start an alternator project now too haha
All the info on this threat is great! Thanks guys, I never really understood what was going on but now I think I have a much better idea how to go about this
« Reply #372 on: June 25, 2011, 08:51:08 am »
In Puharich's writings he talks about using low frequencies just like Meyer did. Which both of their setups were very similar in many ways, but Puharich does make reference to pulsing his cavity with these low frequencies and measuring frequencies at the cavity up into the Ghz range. I have witness some similar effects where I was pulsing at low frequencies just over 2khz and measuring frequencies at the cell over 100khz.
« Reply #373 on: June 25, 2011, 11:15:23 am »
Thats what i was talking about... a microwave for example uses HV dc and create microwaves by accelerating electrons thru the cavity, works like a flute... The cavity configuration might be secret... The microwave is in the rotating modes of molecules... IR is vibration... UV is photoelectric... exitations... anything is photons, the higher the frequency the greater the energy... even RF... but the lower the frequency the bigger is the wavelength...
« Reply #374 on: June 25, 2011, 12:22:55 pm »
A microwave oven 2,4GHz has a wavelength of 12.2 cm, water maser fundamental resonance is around 22GHz, and this is in 1/4 wave length 3,4mm... There are however many modes coming up to 96GHz witch would have a 1/2 wave around 1,5mm stans gap aproximatelly.
The lc is related i think to the spacial displacement of the ions, electrons... But i'm not sure on that... Stan stated so many things... seems more to be in accordance with the laser pulse repetition rate, commonly between 5khz and 10khz...
The time for transition of exited state to spontaneous emission is around 10^-8 seconds, so at least 100MHz frequency.. Lasers to get coherence needs to have more molecules in exited state, and is a matter of probability, so one never goes for the first transition to assure you get more atoms exited... To have stimulated emission you want all the atoms to emit in sync...
As i said water will emit laser but as its photons has low frequency of vibration, in the microwave infra-red range, its called maser. I think historically it came before the laser. Actually a laser is called an optical maser. Water Masers were observed in the universe...
Food for thought
I believe you are on the right track concerning the laser.
« Reply #375 on: June 25, 2011, 14:03:18 pm »
Tony, any idea why you saw this increase in frequency? I've always saw a decrease
