Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 190259 times)
« Reply #392 on: July 17, 2013, 03:39:30 am »
Donald where did you get the bottom text from the picture you posted,cuz' i can find it anywere in the patents...thanks
« Reply #393 on: July 17, 2013, 20:05:55 pm »
Donald can you remember the ouside diameter of your rvic stator?
« Reply #394 on: July 19, 2013, 23:40:11 pm »
Hi Komtek,
There is a drawing of Meyer with the famous third wire at the cell.
If the alternator was electrically isolated from the frame and engine of the bug, then maybe the third wire from the cell was going to the frame / engine.
« Reply #395 on: August 01, 2013, 00:12:00 am »
Hi Komtek,
Hi Komtek,
As promised are here the third wire drawings of Meyer.
It includes an alternator setup...
« Reply #396 on: August 01, 2013, 01:24:18 am »
Thank you Steve,
Yes I was hoping for something I had not seen before.
I am working with these drawings.
Its good to have it posted again.
In Donald's thread here these drawings are quite the ways back.
Third wire to cell is the CT tap to water.
« Reply #397 on: August 01, 2013, 02:30:55 am »
     I was reading the last couple of posts on Meyers third wire. If the 0volts goes to the water of the cell and looking at the diagram of 8-11
The top of the amp inhibiting coil (right side) goes through a diode to the center tapped alternator windings. Where does the ( left side) get
connected to. It says c/t on the end of the wire, what other center tap would it get connected to. Thanks.
« Reply #398 on: August 01, 2013, 04:49:45 am »
Its zero level amplitude.
Gets connected to all three center taps.
You see 1 connected, then another lead from the diode that says CT and he does not show the last one.
Notice all three windings show CT, then 1 more not shown but connected just like the others from the coil 617 another blocking diode 618 then to the last CT.
« Reply #399 on: August 01, 2013, 15:22:15 pm »
    Thanks. So the one winding goes to all three center taps of the alternator. that would almost make another wye winding off each winding there or could be thought of as a 2 phase winding using a balance coil. I wonder if Meyers alternator had 6 or 7 poles. Or a 6pole in  a 7 pole stator.
