Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 190266 times)
« Reply #344 on: February 15, 2011, 13:07:08 pm »
Donald,
How about the 60A resistor?
What do you think of that?
« Reply #345 on: February 15, 2011, 15:29:08 pm »
that picture is a from patent 661, where he was still keeping the chokes a secret, he says in the NZ video that there were a few things he would not tell people when demonstrating the technology, he said he would not tell people about the VIC, and he would not tell people how to make the Magnetized Gas for the EPG.
He says when people came against him he would put the question to them, and they couldn't explain how to restrict amps in a dead short, or how to make magnetized gas at room temp
This was to protect the development, so he was using chokes since 80-81, and didn't mention them explicitly in the patent until about 86, even though if you read the 661 patent carefully there is every indication that he is using chokes if you know what he is saying.
« Reply #346 on: February 22, 2011, 04:11:38 am »
(http://img.photobucket.com/albums/v81/bigbuba/60halfwavein3440rpm12polestockfullwaveout.png)
« Reply #347 on: February 22, 2011, 04:30:03 am »
(http://img.photobucket.com/albums/v81/bigbuba/60halfwaveplus5000squarin3440rpm12polestockfullwaveout.png)
(http://img.photobucket.com/albums/v81/bigbuba/60halfwaveplus5000squarin3440rpm12polestockfullwaveoutzoom.png)
« Reply #348 on: February 22, 2011, 04:37:01 am »
(http://img.photobucket.com/albums/v81/bigbuba/60halfwaveplus5000squarin3440rpm12polestockfullwaveout3phases.png)
(http://img.photobucket.com/albums/v81/bigbuba/freqcomponents.png)
« Reply #349 on: March 10, 2011, 19:39:49 pm »
I tested the RVIC, and I've seen some results that show promise and are worthy of further experimentation. I have not been able to replicate all the conditions stated in the patent yet, so there is more work to do. I wont be working on this again until summer.
This is the biggest topic on the entire forum, and I left it dead for about a year after I first wired up the RVIC and it didn't work, the reason why it didn't work was because in any three phase machine you have to wire one phase backwards, when you do this, it comes alive.
I want to share this video with you all as a hint that there more to learn and results to be gained by building the older systems. The Resonant Cell is all the rage today, and may be a more important path, but the alternator path does work. Stan ran the dune buggy on it, and he wrote in the news letter that he wanted to get it ready for mass production.
The RVIC is 3 VICs in one, it's the same, in just a different form. You can't use a plain old alternator like 50 people have tried, you have to wind a VIC inside it.
Some notes: (and all of these may apply to other VICs too)
The core must be unipolar, you can not have any ac waves in the core, or it destroys the blocking diode pulse action, I had one diode fail and I saw this, so I need more diodes to continue, and these were 1200 volt 30 amp diodes.
I think the grounding is important, not floating, I have more things I want to try in this area.
I have not been able to pulse the rotor yet, I think this is important, the alternator puts out 480-500 Hz with multiple pulses, so the scope sometimes reads 1-2 kHz depending on what it counts as a pulse. It would be nice to slice this up more at 5 kHz
I think my cell is too small. This system was designed to work on a big cell, I think for the same alternator and power, a bigger cell would put out more gas.
1/2 Horsepower motor might be too small, when I put 2 amps into the rotor I know it's near the limit, I did bog the motor down once, as you put more current into the rotor, the voltage goes up a lot, It would be nice to see what it can do with just a little more than 2 amps in the rotor, but Stan said he used 2 amps.
http://www.youtube.com/watch?v=0b3i2JkWz9w#
5072
« Reply #350 on: March 22, 2011, 18:27:33 pm »
(http://img.photobucket.com/albums/v81/bigbuba/rvicwaveformp1p2.png)
5322
« Reply #351 on: March 23, 2011, 01:06:57 am »
your top image kinda somewhat resembles Stephen Meyer's waveform. It looks like it just needs to be tune a little more.
