Author Topic: Rotary Pulse Voltage Frequency Generator Assembly  (Read 190263 times)
« Reply #496 on: October 20, 2013, 16:02:32 pm »
Phases never connect to each other unless you use the isolation diodes, which you should, unless you send each phase to it's own individual tube, which I also tried.
Otherwise they will short out to each other and not do what you want them too... try playing with that on a simulator.
« Reply #498 on: October 20, 2013, 19:34:42 pm »
thanks Donald,i dont trust simulators,can you make a drawing of the phases swich,and some specs of your stator?diameter slots..etc..
« Reply #499 on: October 20, 2013, 22:21:53 pm »
I don't have any measurements for you, it's the normal ford alternator.
Here is the way you connect it with one backwards phase.
(http://img.photobucket.com/albums/v81/bigbuba/Mobile%20Uploads/Screenshot2013-10-20at31731PM_zps958c90e6.png)
« Reply #500 on: October 20, 2013, 23:28:33 pm »
Thanks,normal ford alternator,but its not big case?42 slots?
btw you yt chanel is private,tried fo numerous times to access it...
« Reply #502 on: October 21, 2013, 01:04:45 am »
Thanks,100v on those tubes in series?
« Reply #503 on: October 24, 2013, 02:01:14 am »
tried the phases leads reverse ,nothing!
