Author Topic: New VIC pictures discussion!!!  (Read 52527 times)
« Reply #40 on: February 08, 2009, 23:43:27 pm »
If you can make the bobbins to fit that core,you should be able to get enough wire on it.To get 11.6k ohms of wire on the chokes of my replica of Stans bobbins,I will only need 10 of the 14 grooves.The grooves are only 1/16 wide by 3/16 deep.So you might have enough room if you size it right.The only thing you won't know is the specs for the core material,unless you can get it from MSD.
« Reply #42 on: February 10, 2009, 01:35:51 am »
we need to know what hte msd core is made from to know it's operating frequencies.....has anyone looked up a spec or data sheet for it yet?
« Reply #43 on: February 11, 2009, 02:05:50 am »
i'm not gonna lie but i just went over the multi core section of the tech brief again.....and im still lost.....it is a huge step.
please don't look at these and not read them since they look long.....let's not be lazy these are very important information filled sections i have pulled out.
(http://i2.photobucket.com/albums/y2/kinesisfilms/VIC-WIRE-INFORMATION.jpg)
(http://i2.photobucket.com/albums/y2/kinesisfilms/bobbincavity.jpg)
(http://i2.photobucket.com/albums/y2/kinesisfilms/transformer.jpg)
copper or steel
(http://i2.photobucket.com/albums/y2/kinesisfilms/coppersteel.jpg)
« Reply #44 on: February 11, 2009, 02:14:57 am »
It all makes sense to me , hes cheating with that coil , hes burning off the amps the easy way but hes getting this free inductance boost , hes still getting that "electromotive force" to move those molecules , hes consuming those amps in the coils and the water molecules just loose their electrons and it gets burned off in the coil also , everything is done with that injector and coil ...
Remember how a tesla coil doesnt hurt?
This is the only way I see this happening ... The coil will get hot if Pyre-ML was recommended , trust me I know , very little % of wire gets this coating .
« Last Edit: February 11, 2009, 02:42:19 am by Dankie »
« Reply #45 on: February 11, 2009, 03:22:45 am »
Kinesisfilms,
For (Eq 20)
I have the #s to use for the bobbins Dyno posted.  With 11,600 ohms choke and 10-1 ratio stepup from primary to secondary.   There is room on the bobbin to step it up to about 19 to 1 if you desire.
Choke x 14
N = 112
A = .719
B = .0625
C = .177
Primary x 1
N = 382
A = .875
B = 2.399
C = .125
Secondary x 14
N = 273
A = 1.217
B = .0625
C = .217
If you do the math on this please post it.
« Reply #46 on: February 11, 2009, 03:31:58 am »
The Choke is x 14 x 2
« Reply #47 on: February 11, 2009, 03:38:51 am »
first off the primary and secondary are made of copper as stated above......the bifilar chokes are made of the ss steal.
L is in microhenries not henries
and the only real math here is to take the average radius of the chokes A...THAT IS THE RADIUS IN INCHES CORRECT?.....and use a circumference equation 2*pi*r find our circumference in inches and convert to cm so we can use the SS wire 60 microohms per centimeter and calculate the amount of turns per choke to achieve 11,600 ohms......EACH CHOKE IS 11,600 OHMS as stated here:
(http://i2.photobucket.com/albums/y2/kinesisfilms/percoil.jpg)
just verify the above for me that everything is in inches and is the radius.....and not the diameter....
