Author Topic: New VIC pictures discussion!!!  (Read 52530 times)
« Reply #16 on: January 31, 2009, 14:38:52 pm »
Hi,
My 2 cents on the pictures are as follows:
Its a coilsetup, like a transformer.
There is NO water involved in between the coils of this setup. It uses external electrodes.
I see cable in and outputs.
A coil over a coil is not new in coil-country.
What do we need here?
What i miss is a picture / schematic of the whole setup in which this VIC part is used.
Is somebody able to creat one? Don said that this VIC is used in comby with 1 set of 3 inch tubes.
I have some VIC pics attached which i think are matching the cores on the pictures.
If you look carefull, you see the delrin cores are matching the injectorsystem and have nothing to do with a 3 inch tubecell..... :-\
« Reply #17 on: January 31, 2009, 15:43:29 pm »
There are no more pictures,and I won't be able to get any more.Everything is being sold to Orion.I won't get to see it again.As you can plainly see,the core of the coil assembly is a EI laminate steel stack.There isn't any ferrite rods in this core.That picture is the whole VIC coil in one.And yes Steve this coil is intended to be used with the Injector system.After all it is in the memo 425 for the Injector System.But I do feel that it is the lastest version of the coil that could be a direct replacement for the earlier models as well.You would just wrap the primary and secondaries as needed.This coil would be wound for higher voltages,than the tube cell needs.
As for starting the car,it isn't all together.Some of the components were taken off,by the previous owner.This was done to split up the system,so if the buggy was ever stolen,they couldn't get it to work.All of the pieces are there to put it back together.The buggy was set up with the injector system.But Stan never got to finish it before he died.It was said that he was able to get it to fire but not run.There was an issue of timing everything.The current owner doesn't know how it works and has no desire to put it together or have anyone else work on it.He just wants to sell it.So don't ask why he doesn't do anything with it,he doesn't have time or money or the desire.
« Reply #18 on: January 31, 2009, 16:38:53 pm »
Hi Don,
Well, i ll will not ask you that question. I think you done a great job!
The buggy and Stans paperwork are back in business.
You also took care for those wonderfull pictures of these VIC parts!
For me, it answerd some questions i had!
So, again, great job!
Are you gonna build some parts for testing yourself?
« Reply #19 on: January 31, 2009, 16:55:47 pm »
From what I've read on the VIC it appears to me that the coil is the heart of this circuit.  I believe that the Matrix Circuit is where Stan took the evolution of this coil.
Has anyone ever built the Vic Matrix Circuit Coil and tried to get hydroxy production from a cell with it?
Has anyone ever built it to drive the injector?   I mean besides Stan
I am attaching the two figures to show my reasoning for believing the coil evolved.
« Reply #20 on: January 31, 2009, 18:02:38 pm »
GR8 WORK MR DON,
CAN WE PLS HAVE SOME MORE PHOTOS IF POSSIBLE OF THE VIC.
I MEAN THE WIRES AND THE FERRITE ROD BEING USED,
ALL R ASKING ABT THE BOBBIN ,I WOULD LIKE TO KNOW ABT THE CORE HE USED,
I AM SORRY IF I AM ASKING TO MUCH
RGDS PAUL
LOL , LAY OFF THE CAPS LOCK , YOU LOOK LIKE A NOOB
I think Don has done enough ,  these pictures are simply wonderful . We dont need any new pictures , if you cant understand read up more ...
They gave me good building ideas and clarified a few things , everything makes sense , everything follows the briefing perfectly ...
You can see some sleek building techniques that Stan used to make the bobbin , this is the real thing lol , no doubt about it ...
« Reply #21 on: January 31, 2009, 18:12:41 pm »
I have to disagree with this , Sorry Don ,  you can see Stan going full speed on the highway with this ...
He made that buggy in the 70's , he got killed in 98 . An old investor of his bought some wire from me and told me all about the sequence of events one night  .  @ the end he had a fully working retrofit system , he was this close to taking the retrofit system into the marke , he was making them in secret and wanted to "spread them around" but he got whacked  .
He got his technology running trust me lol , timing and all that crap  was the easy part for Stan , the guy was a genius ...
He simplified that whole buggy into the retrofit system kit we see in the briefing ... That thing would have cost less than 1500$ at the time ...
« Last Edit: January 31, 2009, 19:55:16 pm by Dankie »
« Reply #22 on: February 01, 2009, 16:06:06 pm »
Steve,yes I'm going to make this coil.I just figured out the sizes I need and will be cutting the bobbins soon.I have the delrin now and will need to get the laminates made.And I have a friend working on a control circuit to pulse it.I already have a cell built for the test.I'll take a picture of my cell to post.
« Reply #23 on: February 03, 2009, 15:49:00 pm »
sdvb
