Author Topic: New VIC pictures discussion!!!  (Read 52531 times)
« Reply #24 on: February 05, 2009, 12:19:54 pm »
DynoDon,
About the VIC...
1, If we were to look at it from a top view then: All windings would be counter-clockwise, right?
2, when you mention bifilar windings for the chokes we would have 4 wire ends on the chokes, do you know how they were connected?
(Did the first choke tye into the second choke like the Tesla patent?)
Figure 6-1 only shows 2 wires total signal in and signal out (as far a connection points).
Any further clarification would be helpful.
I don't mean to sound dumb here, just want to build it right so to speak.
Warj1990
« Reply #25 on: February 05, 2009, 16:53:32 pm »
As you see from the picture of the studs sticking out,they weren't hooked up or tied together yet.As for winding,it doesn't matter which direction as long as their all the same way.
Whateven end you start from,those wires will be the one's on the prints with the dot indicator.The chokes would be hooked like the drawings,one on each side of the WFC,and the secondary.Pay attention to the dots.
« Reply #26 on: February 05, 2009, 19:09:41 pm »
dynodon,
i was curious if there were any studs on the other side of the bobbin that we cant see. if so how many.. i think one side of the seconday will conect to one side of choke with a diode in line.. the othere connected on the other side dirrectly so pole orintaion is like stan draws...  since the primary will detterime polarirty of the transfomer right..  i think what really makes it work is having a primary of .030 that is creating a nice magnetic coupling. the .002 seconday can only absorb very little amp activity from being so small then it is going into .004 stainless which is twice its size... sure it has resistance but has twice the dia in capacitance for charge...  we know when installing irrgation that you start with big pipe and as you get into the system the pipes get smaller inorder to build potential/ preasure.. now since u started with 2 inch and downed sized all to 3/4 at the end of the system is this not holding all the potential from being consume like it could be if were just used 2 inch in the hole system.. the 3/4 can only move so much after that potential starts to take over since.. .002-.004 its like upping the size of your pipe from 1/2 to 1 inch.. but ur one inch has a medium in it that works like a reguator to allow potential to stay built up. and can handle the amps from primary so doent heat up.
cheers
outlaw
« Reply #27 on: February 05, 2009, 19:20:32 pm »
EXACTLY!
« Reply #28 on: February 06, 2009, 16:14:20 pm »
The coil had four studs per end.You'l have two for the primary,two for the secondary,and four for the chokes.
« Reply #29 on: February 06, 2009, 17:23:18 pm »
hi don ty for the words
can u give us some more details pls ,
 if u have made it can u pls post the photos of ur VIC pls
rgds paul
« Reply #30 on: February 06, 2009, 18:24:37 pm »
paulsonaivy,
i think dynodon has givien us pretty much all the info that he can about the vic that we dont have.. it is up to us to put the rest together by whats explained in WFC MEMO 425.. for this specific componet.
outlaw
Dutchy
« Reply #31 on: February 07, 2009, 13:23:05 pm »
Hi everyone,
I'n new here on this board, but I have been around on other boards for quite a while already. I have studied the patents and the tech brief and think I'm getting pretty much up to scratch with most things Stan has said and written.
I've seen the pictures of the VIC matrix coil supplied by Dynodon (Thanks great job!) and it fits in very weel with the desriptions in the tech brief.
One thing I'd like to get answered is: Is the VIC matric coil supposed to work with the TRC or is a  very advanced VIC usable with the normal cell too?
I can't really make that out although I think it should work with a cell also....
So, if I were to buy some wire from Dankie and build one of these VICs and use it on a demonstration like cell, can I expect more than average (read: usable amounts) of gas output?
What do you lot on here think about that?
regards,
Dutchy
