Author Topic: New VIC pictures discussion!!!  (Read 52530 times)
« Reply #112 on: February 25, 2009, 03:22:18 am »
ladys and gents,
have you ever had a teacher give you a quiz with like 30 multiple chioce questions..u  fill out all the questions to get to the last one that says now that you are done reading over this put your pencil down and wait for the teach.. the directions were to read over it first.. but instead were allways in a hurry and dont care to take the time to do so.. lol..
i think you will enjoy this post let me know what you think.
tab 39 under mode of operability last page of the water fuel tech.
outlawstc
« Reply #113 on: February 25, 2009, 03:55:04 am »
ladys and gents,
outlawstc
I'm afraid I dont understand that coil , sorry friend .
It is made with an close EI core , see the reference to its core .
  • Yes I got Jolted,
« Reply #114 on: February 25, 2009, 04:01:29 am »
Looks like on that diagram, a cell was meant to be connected inline with the primary. and maybe the secondary was for the injectors or ionizer.. who knows??
« Reply #115 on: February 25, 2009, 04:19:31 am »
Electrojolt , one time you told me you connected 2 transroemers together + to + and you noticed it "ionized the air" ??
Explain more plz , that "non-voltage" ionized the air ?
  • Yes I got Jolted,
« Reply #116 on: February 25, 2009, 05:15:20 am »
You miss-undertood
I used 2 TV transformers to create about 50KV potential between water.
so the Positive of one transformer was on one insolated plate, and the negative of the other transformer was on the other isolated plate.
the other 2 wires were just floating, not connected to anything, and it ionized the Air, I could smell it.
I also connected these two flowing wires to ground, to each other, only one to ground, the other to ground, using chokes, bifilar chokes, smoked some chokes. everything I could think of.
I did countless tests with HV and isolated electrodes. Not even one tini bouble. So if some people claim breaking water using isolated plates/tube they either have leaking insolation or they lying.
By the way, why do you think my screen name is Electrojolt ?
« Reply #117 on: February 25, 2009, 05:32:33 am »
http://www.ionizationx.com/index.php/topic,897.msg8244.html#msg8244
what is the meaning of this waveform ???
I believe the answer to Meyers lies with this .
Included here is a pff written by Tom Bearden , it is hidden by all the pics .
« Reply #118 on: February 25, 2009, 06:17:17 am »
outlaw i can assure you those are in reference to gated pulse trains.....but they are still 50 percent duty cycle pulses going through.....in meyers work this is stated about 98 percent of the time.....and in two photos it shows other wise but if you read the text on those areas it is cleared up.....the images are wrong for 2 even the other images you posted in that reply were 50 percent duty cycle gated......
from what i have read with the frequency being between 0-10khz he has now said what the frequency is that he uses.......i will try to work these backwards to find out the inductance needed to acheieve this.
(http://i2.photobucket.com/albums/y2/kinesisfilms/NUMBERS1.jpg)
(http://i2.photobucket.com/albums/y2/kinesisfilms/NUMBERS4.jpg)
the diode type needed.....i once bought a diode that was to replace one of his mentioned diodes from the patent but it never worked.......i still have it since i am unsure if it activates only at high voltages.
(http://i2.photobucket.com/albums/y2/kinesisfilms/NUMBERS2.jpg)
THIS STATEMENT HERE SHOWS THAT RESONANCE IS THE DOUBLE PULSE FREQUENCY HITTING THE CAPACITOR AND NOT THE FREQUENCY GATED.....IT STATES THAT THE RESONANCE IS SEPERATE FROM THE GATING.
(http://i2.photobucket.com/albums/y2/kinesisfilms/NUMBERS3.jpg)
this entire thing is an important read....basically saying that to consume 5 gallons in one hour you need more pulses hitting the water molecule aka higher frequency (more pulses)...with a higher frequency the water dissasociates faster at resonance.
(http://i2.photobucket.com/albums/y2/kinesisfilms/NUMBERS5.jpg)
(http://i2.photobucket.com/albums/y2/kinesisfilms/NUMBERS6.jpg)
and once again stating the exact measurements of the tube cell...
SO WITH THIS FREQUENCY GIVEN FOR RESONANCE AND THE EXACT TUBE LENGTH WE CAN REVERSE WORK THIS TO FIND THE INDUCTANCE HE USED TO ACHIEVE RESONANCE.
« Reply #119 on: February 25, 2009, 08:22:28 am »
so who wants to know the secret lol  i beleave i hold the answer to understanding rotary vic once and for all.  i will explain when i get off work tomorrow gotta get some sleep.  your really gonna like what i have to say because it fixes all problems of understanding.. at least i hope so lol.
outlawstc
