Author Topic: New VIC pictures discussion!!!  (Read 52526 times)
« Reply #32 on: February 07, 2009, 15:50:31 pm »
This question has already been asked.Yes it appears that this coil was for the TRC (injector),but as I said earlier,I think it replaces all previous models.But it would require a different winding ratio,that we will have to work out for ourself.Just because we have a coil doesn't mean it will work.You still need a pulse circuit to run it.
« Reply #33 on: February 08, 2009, 00:05:19 am »
does anyone have a source for th EI core? is it 3/4 x 3/4 for the center and 3/4 x 1/2 for the perimeter?
« Reply #34 on: February 08, 2009, 00:56:06 am »
The EI core would have to be custom made.It's not a off the shelf size.It is 3/4" square and the outside legs will be half the size of the center leg.The standard would be 3/8" wide.I'm talking to a company now to see about getting some made.Plus these laminates are thinner than normal also.
« Reply #35 on: February 08, 2009, 02:29:17 am »
Food for thought .The E core in the picture looks in close resemblence of the GM HEI ignition coil used in the earlier electronic ignition systems tha are mounted in the distributor caps.
« Reply #36 on: February 08, 2009, 15:34:18 pm »
Not even close in size to a HEI from GM.This coil is twice the size.I'm quite familiar with the HEI junk GM sells.Two different coils.You will have to get them custom made like I already said.Or you can prove me wrong.Good luck with that.
« Reply #37 on: February 08, 2009, 20:15:36 pm »
I know your response to the GM coil, DynoDon.
However...
I just happen to have one and don't own a GM anything.  It was on sale 2 years ago at Advanced Auto - so I figued why not.
Now, do I just put it back in a box and continue storing, or get the grinder?   ;D
Warj1990
« Reply #38 on: February 08, 2009, 21:33:18 pm »
Nice find bro , Looks like the right size.
If its silicon steel good with high freq and thin enough its good ...
« Reply #39 on: February 08, 2009, 22:44:02 pm »
MSD Core:
3 inch by 3 inch outside to outside.
5/8 inch center leg, 5/8 inch depth also.
3/8 inch end legs, 5/8 inch depth also.
Does close count?
I now need to know how important 10 ohms per foot is (to prevent amp flow and make a static transformer).
I have some 43 and 45 awg wire - don't know if that will work right
Still need an old sewing maching to build a coil winder.
Warj1990
« Last Edit: February 08, 2009, 23:18:06 pm by warj1990 »
