To update the board, resonance has been blocked by secret society. Off topic here, I have produced the gas Stan talked about during resonance. It is high voltage and no current, or very little current. I am descreet about what I share and do not wish to share much because I have already became a Target and I am on the watch list. With this being said I will point you to where you need to be.
Mosfets, fets, transistors, everything along the lines of semiconductors or anything that's been doped with silica is useless for resonance because resonance occurred at very high frequencies. How to bypass this issue follows. Before said, resonance can be seen with a few for very short periods before the glass base self destructs. A fet will not be base sensitive triggered but will still function and will operate at it's opposite on off state, and will no longer be sensitive. As the alternate setup works but then fails and it's unclear to the tester that the fet still functions but becomes un-sensitive at it's base after a static charge destroys it's base in a way the fet is still useful and still functions. This leaves the tester scratching his head in confusion.
The answer to the problem is Tesla, he used a glass vacuum triod or the like. Easy to Homebrew And a very high powerful switch that can hit frequencies in the millions. Coil at these frequencies become capacitors. I have first handely built such a circuit that will dissosociate extremely insulated none conductive distilled water that proves this technology to work. But it's not just about the fuelcell. This frequency also is why the Hutchison can do things you can't comprehend. His devices operate with glowing vacuum resonaters like those Tesla used. Anode cathode and base or the like, these thing have to be heated before they work. Put this forum on down low, be quite about it. Test vacuum mosfets and let the tube power a coil directly and switch it with a external coil. You will see this effect on how the switching coil then starts it's resonance and becomes staticly charged.
I will end this post with a generic wchematix that proves the claim. Power any coreless coil of around 20 to 30 ohms, using a diode charge a capacitor,s let the cell connect at one pole and mm arc at the other, around 2000hz tou can see this effect, you will see large cleAn bubbles. Let this lead you to the vacuum tube and higher power, not just for the fuel cell but for many other things, even an5igracity and time travel. Be careful, and most importantly be quite.
