Author Topic: Secret technology, Tesla stan  (Read 6787 times)
0 Members and 29 Guests are viewing this topic.
Re: Secret technology, Tesla stan
« Reply #16 on: May 09, 2019, 06:38:40 am »
photos
« Reply #17 on: May 09, 2019, 06:43:30 am »
« Reply #18 on: May 09, 2019, 06:45:31 am »
3
« Reply #19 on: May 09, 2019, 06:48:40 am »
4
« Reply #20 on: May 09, 2019, 06:53:20 am »
5
« Reply #21 on: May 09, 2019, 15:14:26 pm »
when you start playing with the circuits you will start to see large water bubbles and you will hear popping inside of the cell there will be times it will sound like they sell will try to pop and jump off the table. Some of the results that I have seen has nothing to do with Stanley Mayer. I have noticed after they sell jumps is usually when you first connect it if it's going to do it for some reason it only happens with fresh water but this is where the research needs to be is in this area. I was limited on time so I could not go into great detail like for example The Dodd maybe on the output of the choke and not the input I drew these schematics from memory and you may need to play with them. I just got done installing pistons in my car for the second time thank God it's running right and I am dealing with raising four children so I am sorry that I am limited on time and there might be a era here and there but there is enough here to get anyone going. Some of the stuff my look familiar but don't knock it until you try it an experiment with it. I am aware of Stan's v i c and that is not exactly what I am posting here that stands v i c I have found to be a resonant circuit that you cannot only use on a fuel cell but it is the back EMF that is in resonance rather than using a shunt you use a capacitive coil. Also do not shunt the primary transformer as it kills everything the fat mechant it a little but there is high voltage at the primary with no shunt and at the right frequencies the fat will never get warm and current will not be a problem this is all cold. If your stuff is overheating refer to example 2. the potential mater change the polarity voltage difference at the gate and must be tuned far the call to properly operate and resonate you can go by ear or you can use an oscilloscope you can hear the resonant peak points for whatever given frequency you are on. With that said try 1000 to 8000 Hertz those are the golden areas and the spark between the Gap is in the millions. Then around 15000 Hertz is another are. Start with the lower thousand Hertz frequencies and understand what is going on before you move up. And these are iron cores primaries.
« Reply #22 on: May 09, 2019, 23:12:02 pm »
Hi Brian,
Thanks for the drawings! Well done.
So picture 3 is the one that got you the big bubbles etc etc?
cheers!
« Reply #23 on: May 10, 2019, 00:31:27 am »
Yes!
