One more thing I was thinking about. There's a compound called simeticone (found in GasX) which changes the surface tension of water, causing small bubbles to merge into larger bubbles. What if the capacitive coil is producing some kind of exotic energy which affects surface tension? According to my analysis, surface tension is a Gauge effect, similar to gravity.
