Author Topic: Secret technology, Tesla stan  (Read 6785 times)
0 Members and 28 Guests are viewing this topic.
Re: Secret technology, Tesla stan
« Reply #96 on: June 09, 2019, 10:06:21 am »
I didn't mean to say Farraday made bubbles.
All I know is if you build my circuit, and you get the results I did, you will see a differenty Type of electrolysis then what we are use to seeing.
« Reply #97 on: June 11, 2019, 09:53:00 am »
i found an old clock radio that will be killed for the good of mankind
« Reply #98 on: June 13, 2019, 07:48:03 am »
lol,! Also, when you're done with that,,,, Hehe,,, Ima show you another deal thats totally not norma, so, try and find the secondary to a microwave oven transformer. if you dont have that, a heave fine coil like a mot. Mine is from a mot but an air core.
So, lets see what happens with your setup first.
« Reply #99 on: June 13, 2019, 07:49:18 am »
Again, you're not looking for mass production with the setup you are constructing, you are looking for something that is not normally possible.
« Reply #100 on: June 13, 2019, 14:22:13 pm »
I'm in the stages now i'm producing a good amount of gas with a micro transistor! Updates soon...
  • Build it. Power it. Use it.
« Reply #101 on: June 14, 2019, 17:51:58 pm »
Those oven transformers are welded with soft iron electrical welding rods, for optimal magnetic performance.  The seams are extremely easy to cut with a hack saw.  If you had two identical MOTs, you could hammer the coils out, then reassemble them, each with two like coils.  Each transformer, wired in self opposition, would then comprise a choke.  And the one with two secondary coils would be good for High Voltage applications.  Also, you don't have to reweld the seams; just clamp the cores with a hose clamp. Or use JB Weld epoxy to hold them together permanently.
« Reply #102 on: June 15, 2019, 15:04:18 pm »
Si finally i slaughterd the 30 year old clockradio of my wife...She cried, but who cares.... ;)
The primary reads 1026 ohms
Is that better?
And btw, i do have several MOT,s
So which one to do now?
And how many tubes of my cell shall i use?
cheers!
« Reply #103 on: June 15, 2019, 20:26:42 pm »
That may give a good result! Try it...
