Author Topic: The Dc resonant transformer  (Read 29931 times)
  • let the voltage do the work
Re: The Dc resonant transformer
« Reply #104 on: January 21, 2014, 18:59:57 pm »
I don't mean to leave the battery connected how can you permanently charge them when they are fart apart from each other using a battery?
« Reply #105 on: January 23, 2014, 00:34:13 am »
what about a capacitor inside a capacitor?  ::) ]
« Last Edit: January 23, 2014, 08:42:15 am by geon »
« Reply #106 on: January 24, 2014, 17:58:36 pm »
charge a paraller plate capacitor C1 , form another capacitor C2 enclosing C1, charge C2 no opposition exists, C1 voltage is increases ,C1  energy is higher where did the energy come from? C2 capacitance doesnt change if C1 is charged or discharged from what I've checked but I can be wrong.
« Last Edit: January 24, 2014, 18:40:40 pm by geon »
« Reply #107 on: January 25, 2014, 12:33:20 pm »
You forgets that if c1 is in the middle of C2 you need to add the c1 voltage  + over voltage to e able to charge c2
make a drawing and think about
« Reply #108 on: January 25, 2014, 13:59:19 pm »
but the electric field outside (an ideal) capacitor is zero what do you mean?
« Reply #109 on: January 26, 2014, 05:14:13 am »
Geon there is a difference of potential there, for example if you charge the first capacitor and than you complete your construction and than you short the c2 what happens?
C1 discharges and charges the c2
« Reply #110 on: January 26, 2014, 11:19:04 am »
ΔV=-Ed=0 outside any capacitor ideally isn't it correct? so no work is possible by C1 on C2 ... only by C2 on C1.. and I don't understand why should C1 discharge if it's not connected to anything ? I'm not that good of an artist but here is how it should look like, read pm I explain it better.
« Last Edit: January 26, 2014, 11:49:54 am by geon »
« Reply #111 on: January 27, 2014, 13:31:35 pm »
do you agree that to charge the C2  cap you need its electric field to cross the region with electric fields C1?
The electric field is zero outside a capacitor but the potential is not!
