Author Topic: The Dc resonant transformer  (Read 29899 times)
0 Members and 30 Guests are viewing this topic.
Re: The Dc resonant transformer
« Reply #64 on: January 13, 2014, 03:19:34 am »
I did the first tests….
result two 1200 v 30 a transistors burned…
lot of questions….
The induced voltage is tremendously high in the secondary…
the primary has 360 turns and the secondary 220 turns the voltage in the secondary goes up to beyond than 500v applying less than 10v to the primary… but no power if loaded…
more to come…
« Reply #65 on: January 13, 2014, 09:27:13 am »
which setup did you try? how much current in the primary?
« Last Edit: January 13, 2014, 10:07:10 am by geon »
« Reply #66 on: January 13, 2014, 14:06:48 pm »
$ 1 5.0000000000000004E-8 26.59566520631553 41 5.0 43
v 144 192 144 128 0 0 40.0 100.0 0.0 0.0 0.5
d 304 128 368 128 1 0.805904783
T 368 128 448 208 0 0.5 0.01 0.8523545670853866 -41.24698620367449 0.999
T 448 128 544 208 0 9.999999999999999E-5 100.0 41.24698620367449 -0.19314683362971596 0.999
d 304 208 304 128 1 0.805904783
d 304 288 304 208 1 0.805904783
c 368 208 304 208 0 3.0000000000000004E-8 -97.73968505858734
c 224 128 224 208 0 0.01 99.99461461908601
g 224 208 224 240 0
w 144 128 224 128 0
w 224 128 304 128 0
g 144 224 144 240 0
w 368 208 368 256 0
l 304 288 304 336 0 0.001 8.673617379884035E-18
g 304 336 304 368 0
w 368 256 432 256 0
w 432 256 432 304 0
f 384 320 432 320 0 1.5
g 432 368 432 400 0
w 432 336 432 368 0
w 432 368 464 368 0
w 464 368 496 368 0
w 496 368 544 368 0
d 464 368 464 256 1 0.805904783
r 496 368 496 320 0 1000.0
z 544 368 544 256 1 0.805904783 560.0
c 496 320 496 256 0 1.0E-8 -3.7428177872588817
w 432 256 464 256 0
w 464 256 496 256 0
w 496 256 544 256 0
v 384 368 384 320 0 1 10000.0 15.0 15.0 0.0 0.5
g 384 368 384 400 0
r 544 128 544 208 0 500.0
r 144 192 144 224 0 0.01
o 32 64 1 291 160.0 9.765625E-5 0 -1
o 0 64 1 291 320.0 9.765625E-5 1 -1
this is the circuit i used…
(http://www.ionizationx.com/index.php?action=dlattach;topic=2817.0;attach=13233;image)
the connections are exactly like the drawing of the 2 toroids… except the feedback winding in the primary core is only serving as a voltage limiting coil
The strange thing is the voltage at the secondary… too high
« Reply #67 on: January 13, 2014, 17:55:42 pm »
this?
(http://www.ionizationx.com/index.php?action=dlattach;topic=2817.0;attach=13219;image)
« Reply #68 on: January 13, 2014, 21:43:49 pm »
Yes but on the right there are three cores together i ill do a picture…
« Last Edit: January 13, 2014, 22:37:04 pm by sebosfato »
« Reply #69 on: January 13, 2014, 22:28:29 pm »
YAWN
« Reply #70 on: January 14, 2014, 03:53:46 am »
today i bought more 8 transistors 1199v 30A
« Reply #71 on: January 14, 2014, 08:01:21 am »
where do you put the 3 cores?
« Last Edit: January 14, 2014, 08:51:56 am by geon »
