Author Topic: The Dc resonant transformer  (Read 29898 times)
0 Members and 30 Guests are viewing this topic.
Re: The Dc resonant transformer
« Reply #72 on: January 14, 2014, 16:55:46 pm »
the drawing is an up view the toroid at the right side has 3 toroids one over the other …
« Reply #73 on: January 14, 2014, 18:58:29 pm »
isnt it possible for electrons from ground to go to a more positive potential?
« Reply #74 on: January 14, 2014, 19:07:35 pm »
what do you mean with that?
To exist a positive potential mean that the ground already has an excess
« Reply #75 on: January 14, 2014, 19:30:01 pm »
the ground is supposed to have 0 potential so the electrons from ground should go to a more positive potential right? http://jnaudin.free.fr/kapagen/ this uses ground potential .. damn where's the mistake?
« Last Edit: January 14, 2014, 23:55:55 pm by geon »
« Reply #76 on: January 15, 2014, 04:00:21 am »
well i don't know.
I'm trying this idea just because it made sense to me.
the idea is that as the secondary of the first transformer (the shorted turn) induces a voltage at the other transformer and this helps induce again in the primary ...
The epg
« Reply #77 on: January 15, 2014, 04:03:55 am »
I was thinking about the epg
If you have a coil around a tube and energizes it, it induces a current in the tube to create a magnetic field that opposes the magnetic field of the coil… my point is inside the tube the polarity is reversed so any magnetic force it cause to a permanent magnet inside the tube is contrary to the induction….
so i'm considering the field inside the tube is contrary to the field outside it.
« Reply #78 on: January 15, 2014, 08:29:23 am »
why is there more voltage than normal in your secondary??
epg
« Reply #79 on: January 15, 2014, 09:47:57 am »
This is the same principle applied to epg analysis
(http://www.ionizationx.com/index.php?action=dlattach;topic=2817.0;attach=13237;image)
In my point of view the primary induces a current in the tube that create magnetic field in the other direction… so the magnet should be accelerated in a direction that reduce the field inside the tube and this direction is the direction that could induce further current in the tube that create further acceleration…
In the idea of the transformer is the same but instead of give the magnet the ability to move is uses the flux of the shorted turn to generate voltage into a magnetic circuit
My question is, is that correct?
The field inside the tube is in the opposite direction? There can be a net south pole?
The magnetic field inside of a tube carrying dc current is 0. but the current should be in another direction …
« Last Edit: January 15, 2014, 10:17:08 am by sebosfato »
