Forum for alternative environment friendly technology research
Home
Help
Login
Register
A green and clean environment is a human right!
Projects by members
Projects by members
Sebosfato
(Moderator: Login to see usernames) »
The Dc resonant transformer
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
Go Down
Author
Topic: The Dc resonant transformer (Read 29901 times)
0 Members and 30 Guests are viewing this topic.
Sr. member
let the voltage do the work
Re: The Dc resonant transformer
Reply #32 on:
January 04, 2014, 17:39:49 pm »
won't L2 try to maintain the magnet's magnetic field ? this is like putting an air core tranformer aligned to a homogeneous magnetic field.. is there something I'm missing?
Logged
Global Moderator
Hero member
Reply #33 on:
January 04, 2014, 18:30:57 pm »
When?
Logged
Global Moderator
Hero member
Reply #34 on:
January 04, 2014, 18:33:12 pm »
From my analysis the secondary aways mimic the primary magnetic field during pulse on except if the field cross the zero point.
Logged
Sr. member
Reply #35 on:
January 04, 2014, 19:20:26 pm »
the core field is decreasing so the secondary coil will create a field to keep the field from decreasing .... opposite to the primary coil's field.... I'm I wrong?
Logged
Global Moderator
Hero member
Reply #36 on:
January 04, 2014, 19:49:13 pm »
during pulse on?
Logged
Sr. member
Reply #37 on:
January 04, 2014, 20:10:57 pm »
yes ... during pulse on the field is decreasing isnt it?
Logged
Global Moderator
Hero member
Reply #38 on:
January 04, 2014, 22:35:11 pm »
Yes the field is decreasing. But do you agree that if it were a normal transformer the field would be increasing because of the primary? So in the case of a transformer the positive into the dot and positive out of the secondary dot.
Logged
Sr. member
Reply #39 on:
January 04, 2014, 22:43:02 pm »
yes.. but put a coil inside a magnetic field and reduce the field strength , the coil will create a magnetic field to resist this change in field strength.. in the direction of the field..
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
Go Up
Projects by members
Projects by members
Sebosfato
