Author Topic: Stan Meyer Videography and Discussion Update  (Read 19600 times)
  • let the voltage do the work
Re: Stan Meyer Videography and Discussion Update
« Reply #32 on: December 10, 2013, 10:04:58 am »
fabio center tube is a hollow conductor..but meyer is said to have used 2 tubes not 3 , in that case ionic water is the center tube too seperated by dielectrics (insulators).
similar ->http://jnaudin.free.fr/wfcbooster/images/WFCVIC11sig.jpg
« Last Edit: December 11, 2013, 00:28:04 am by geon »
« Reply #33 on: December 11, 2013, 08:13:47 am »
Yes to all that but grounding the center electrode would do nothing at all other than forming a ground plane.
« Reply #34 on: December 11, 2013, 08:33:53 am »
 the inside region has no external fields, ground is part of the circuit.  voltage is slightly higher because of this.
« Last Edit: December 11, 2013, 10:14:35 am by geon »
« Reply #35 on: December 12, 2013, 12:49:18 pm »
In meyer documents you can find the tube cell arrangement with two tube sets where the inner tubes are soldered together in a disk. And in this same drawing he describe by little arrows that one outer tube is positive and the other is negative.
If you get to read all the patents that cited meyer and the patents they also cited and so one is easier to understand why meyer talked its about movement and  deflection of electrons.
If you remember well physics, Inside a hollow conductor the field is zero, a dielectric don't have moveable electrons, the field outside of a capacitor is zero,
« Reply #36 on: December 12, 2013, 18:10:42 pm »
this is not how I thought it could work.. can you show me these documents?
« Last Edit: December 12, 2013, 18:54:52 pm by geon »
« Reply #38 on: December 13, 2013, 09:54:25 am »
what page are these tube sets? didnt find them
« Last Edit: December 13, 2013, 11:10:00 am by geon »
« Reply #39 on: December 13, 2013, 14:03:13 pm »
(http://www.ionizationx.com/index.php?action=dlattach;topic=2799.0;attach=13148;image)Page 28
Notice the arrows which indicated the left outer tube is positive and the right outer tube is negative .... the inner tubes should be at zero volts
