Author Topic: Stan Meyer Videography and Discussion Update  (Read 19596 times)
Re: Stan Meyer Videography and Discussion Update
« Reply #48 on: December 14, 2013, 12:02:36 pm »
J.P. the alternator in the picture still consumed 40A at 12v from test results shown in the independent test ev.  ....and the gas flow was measured after it was presurised..so still faraday electrolisys.Do you know details about the r-vic alternator which run the buggy?
Again i asked,who were the cheaters in the Indi500?Thanks!
« Reply #49 on: December 16, 2013, 04:17:34 am »
All I know is what I saw.
The alternator run by belt from electric motor...same as in buggy idling video.
Pressure build up in cell @ 10w power...2a x 5v on black box meters...
Lab video will show more...
Lender/escrow/broker cheaters that were to lend 350k for Indy Fuel Cell build kept my 5k deposit supposedly because I didn't perform by showing them the buggy running which was never in the deal.....
Couldn't waste time and more money suing them.....lesson learned...
Cheers,
jp
« Reply #50 on: December 16, 2013, 13:52:55 pm »
(http://www.ionizationx.com/index.php?action=dlattach;topic=2799.0;attach=13148;image)Page 28
Notice the arrows which indicated the left outer tube is positive and the right outer tube is negative .... the inner tubes should be at zero volts
I think half the tubes must have phase delay that's why he shows the arrows like this but why has he 9 tubes instead of 10?
are the inner electrodes tubes or rods ? he must be hidding something..
« Last Edit: December 16, 2013, 14:08:07 pm by geon »
« Reply #51 on: February 13, 2014, 19:38:05 pm »
If you had a water capacitor charged there is a point where the voltage potential is zero, exactly in the middle of the capacitor. If it were floating ground or isolated ground during charging.
If you connect one of the leads of a charged capacitor to ground?
Basically nothing because the net charge is zero, the only think is that you are going to relocate the zero potential.
Ex you connect the negative side of a capacitor charged to 40kv while isolated, to ground. what happens?
Well as the negative side is more negative than ground electrons should go to ground? If this could happen you would end up with charge imbalance on the capacitor? I guess the answer to that is to think in this way since a capacitor work based on bound link charges the above statement is impossible since the polarization of the dielectric holds the electrons or the capacitor would get discharged!
This ability allow the choice of an arbitrary ground in whatever circuit and still calculate the potentials unaffectedly.
Stan repeatedly talks about water having zero charge because it has zero charge but is not neutral under all conditions.
If you apply a greater E field than the one that holds those ions together they will split apart and now you have a zone of net positive charges and another with negative charges. (still net zero)
Now if you neutralize this second field but allow some electrons to burn off from the circuit during this discharge than its clear the water will take up a positive charge probably going out in gas form...
This sounds close to what I understood from Stan.
When the molecules, ions, etc. are pos or neg they are unstable/seeking stable/neutral state....or 0 state.
After Electrical polarization you have H2 and O2 gas..diatomic....
"Pluck off the free electron and it can't recombine.."
It is moving faster in a sense because they are all ions that can't combine...
this is FIRST STEP from ELEC POLZN TO HYD FRCTRNG.
JP
More later.
jp
« Reply #52 on: February 14, 2014, 02:59:37 am »
fabio center tube is a hollow conductor..but meyer is said to have used 2 tubes not 3 , in that case ionic water is the center tube too seperated by dielectrics (insulators).
similar ->http://jnaudin.free.fr/wfcbooster/images/WFCVIC11sig.jpg
ALWAYS TWO "VOLTAGE ZONES."
JP
« Reply #53 on: February 27, 2014, 22:55:10 pm »
« Last Edit: February 28, 2014, 01:28:00 am by MeyerandMe »
« Reply #54 on: February 28, 2014, 00:34:54 am »
Hello Jim,is there a chance that we could see the new videos with Stan that you tease us in the end of 2013,you said that will be released spring 2014...
Thanks!
« Reply #55 on: February 28, 2014, 02:06:42 am »
audio filtering and conversion to text subtitles is about 90 % done on one of the videos  but attention has been turned now to some other document processing
