Author Topic: Spikes Cell  (Read 34817 times)
Re: Spikes Cell
« Reply #32 on: March 27, 2008, 22:27:44 pm »
it has to be pulsed to the rotor, and you cant have a alternator cap, they will remove the spikes,, but some caps dont, you can get more gas with caps if you know how to use them...
Re: Spikes Cell
« Reply #33 on: March 27, 2008, 22:59:50 pm »
Today I tried  12vdc at 1amp, up to 12vdc at 10 amps to the rotor. And found no difference in gas out put.  :-\
I thought if you created a better magnetic field, It would increase production. But it appears  1 amp is enough.
Spike
Try higher volts!
  • OO-Rah!
Re: Spikes Cell
« Reply #34 on: March 27, 2008, 23:48:10 pm »
I think you lost me.  ???
Ok Hydro,
What I'm getting is, run inline capacitors with a blocking diode I assume.  And if so, How big, 250v or what.
And Steve you said higher voltage. Do you mean to the rotor, or rewire the alternator to 24 vdc
Looking for answers
Spike
Re: Spikes Cell
« Reply #35 on: March 28, 2008, 09:13:28 am »
On the rotor. If you have a variac, that would be nice to put on the rotor. Then you can play with variable dc voltage on the rotor.
  • OO-Rah!
Re: Spikes Cell (Karebill Style Cell)
« Reply #36 on: May 08, 2008, 03:55:50 am »
Karebill
I finally scrounged enough 316L SS tubing for my cell  ;D
Tomorrow  I start truing up, and prepping my tubes.
I'll keep you all posted.
Spike
Re: Spikes Cell
« Reply #37 on: May 08, 2008, 04:03:31 am »
oh man those are  nice,,, i want them lol.. do you have any ideal of your gap size yet?
Re: Spikes Cell
« Reply #38 on: May 08, 2008, 05:03:48 am »
I cant wait to see it in action. Stainless is getting hard to find anymore and its expensive. I used to work in a battery plant and everything there was made from c20 a verry high grade. That plant would be impossible to build because of the cost of stainless now.
  • OO-Rah!
Re: Spikes Cell
« Reply #39 on: May 08, 2008, 05:11:00 am »
It's will be a six cell, three tubes each 1", 3/4", And 1/2", 10 inches long. With a 1.5mm gap. the water will flow back and forth between all the tubes before exiting, With the help of a pump. hooked in series.
Spike
