Author Topic: Spikes Cell  (Read 34853 times)
  • OO-Rah!
Re: Spikes Cell
« Reply #56 on: May 14, 2008, 21:15:02 pm »
Lapperl
It looks like it will be a sweet setup.
Can't wait to see it.
Spike
  • OO-Rah!
Re: Spikes Cell (Karebill Style Cell)
« Reply #57 on: May 17, 2008, 08:19:00 am »
It's been a couple of days, Thought I would give you all an update.
After considering a number of things, I decided to build manifolds for the ends. This way it would be compact, Free flowing, And maybe, More efficient. ;D
Hope you like it
Spike
  • OO-Rah!
« Reply #58 on: May 18, 2008, 02:32:20 am »
 ;D MY CELL IS BUILT !!!!  ;D
I spent the afternoon fitting each piece. I cut down the pvc tees to conserve space. Then slotted them and slid a piece of 3/4 pvc tubing threw them. After I glued  all the pieces together, I epoxied the manifolds to the cell.
Tonight I will start on the reservoir, And monday I will find a pump. Because I have to fire this up!!
I want to thank Karebill and everbody else for there help so far.
Spike
target
Re: Spikes Cell
« Reply #59 on: May 18, 2008, 02:36:48 am »
just curious how did you make the connections on the inner tubes and how did you route them out from under the pvc?
Re: Spikes Cell
« Reply #60 on: May 18, 2008, 02:40:53 am »
Nice!   I wonder how much pressure can it hold compaired to stan's style...?
  • OO-Rah!
« Reply #61 on: May 18, 2008, 02:58:47 am »
Thanks, I've been working hard on it.
Hopefully I will find out monday, How much psi it can stand. But what I can't wait to see, Is what it can produce.
Spike
  • OO-Rah!
« Reply #62 on: May 18, 2008, 09:52:54 am »
H2OPOWER
Unfortunately, I will be using grunt power for now. I fried my circuit, And rather than rebuild it, I was thinking of a Bob Boyce  circuit. Hooked to a 30 amp relay. Along with an AC inverter.
Mechanically, I can build what ever I want to. But electronics, I definitely have to follow directions. And still require some assistance. My last circuit was Hydro's old design. I learned a lot from building it. Same with my first cell.
A man once told me that a day without learning something, Is a waisted day.
Spike
  • OO-Rah!
« Reply #63 on: May 19, 2008, 02:49:17 am »
Does anybody else have this problem. These are pictures of under the hood of my 2006 Sebring convertible. When I said space was at a premium, This is what I mean. There isn't even room for the battery, It's inside the fender well. My cell is going to be installed in front of the radiator.
Spike
