Author Topic: Spikes Cell  (Read 34791 times)
  • Look out for the M I B
Re: Spikes Cell
« Reply #64 on: May 19, 2008, 02:53:52 am »
Put ur cell in the back and run a line up to a bubler in ur engine compartment, most engine compartments hawe room for a bubler of some sort
Mr Brown / H2inICE
  • OO-Rah!
Re: Spikes Cell (Karebill Style Cell)
« Reply #65 on: May 20, 2008, 05:21:13 am »
First trial run of my karebill cell
I hooked my rotor to my stator and got 25VDC at 20 amps. This is with my 1/2hp 1800rpm motor
On Tap water I got 210 - 220 cc/min, At 24.1VDC, 8.2 amps
with 4 tspn lye I'm getting a little over 1.25 LPM, At 24.2VDC, 18.2 amps
I ran it for an hour, There was no slow down in production. And I don't think it made it to 100 degrees.
here is the video http://youtube.com/user/bulldogge1232000
or you can download it
Spike
hydro
Re: Spikes Cell
« Reply #66 on: May 20, 2008, 08:39:15 am »
great job spike! great job!
  • OO-Rah!
« Reply #67 on: May 20, 2008, 09:13:37 am »
I have been playing for the past couple of hours.
Here is my best result so far
1.33 LPM
13.8 VDC
18.2 amps
251.16 watts
5.307 ml/watt
And still playing  ;D
Spike
Re: Spikes Cell
« Reply #68 on: May 20, 2008, 09:26:26 am »
First of all great job Spike 8)
I just updated the comperison chart with spike`s results.
From what I see I think that no neutral tube setup and extreme small gap is the way to go for best efficiencies
HM
  • OO-Rah!
« Reply #69 on: May 20, 2008, 09:36:49 am »
Thanks  ;D
But give me some time.
And how do you find the efficiency?
I was looking, but couldn't find it.
Spike
Re: Spikes Cell
« Reply #70 on: May 20, 2008, 13:54:28 pm »
Looks great Spike!!  Good work.
I was curious about a couple of things and was wondering if you would answer a couple of questions?
How do you have your system wired?
How did you keep your neutral tubes isolated?
Where did you get your pump?
Keep up the good work!!
LapperL
Re: Spikes Cell
« Reply #71 on: May 20, 2008, 14:29:37 pm »
 That’s interesting that yours will run without the pump. Mine drops production considerably with the pump off.  Maybe it’s my small gap size? Try different wiring setups. When using lower amps mine makes the best production with a 3 series 3 parallel. Very nice.
