Author Topic: Spikes Cell  (Read 34843 times)
  • OO-Rah!
Re: Spikes Cell (Karebill Style 12 Cell)
« Reply #88 on: June 04, 2008, 01:17:59 am »
 ;D Over a liter a min
I got it back over a liter/min, but gave up some efficiency
.8955 LPM or 67 sec/L               1.091 LPM or 55 sec/L
8.1 amps                                   11.8 amps
12.2 VDC                                   12.7 VDC
98.82 watts                                149.86 w
9.06 ml/min/watt                         7.28 ml/min/watt
7.5vdc .5amp to rotor                   4.5 vdc .7 amps to rotor
But I'm working on it.
Spike
Re: Spikes Cell
« Reply #89 on: June 04, 2008, 03:08:20 am »
good work spike, im working on my cell right now...mmuuahahahaha
  • OO-Rah!
Re: Spikes Cell
« Reply #90 on: June 05, 2008, 22:41:01 pm »
Here is how i built it
karebill build
The new one will be a dry cell as well.
I cut fishtank airline down the middle for spacing(1/16"), until I epoxied it. Give at least 1/8" for the epoxy to go down in between the tubes
Here are some pics
http://tinypic.com/view.php?pic=jgsc39&s=3
http://tinypic.com/view.php?pic=2tshw&s=3
http://tinypic.com/view.php?pic=wildg6&s=3
http://tinypic.com/view.php?pic=2yw7ih3&s=3
http://tinypic.com/view.php?pic=2np6f&s=3
http://tinypic.com/view.php?pic=2sbmzdh&s=3
It's best to epoxy the two tubes on the exit side first, before the outside tube is installed. Hope it helps.
Spike
Just trying to share  ;D
  • OO-Rah!
Re: Spikes Cell (Karebill Style 12 Cell) NO ADDITIVES
« Reply #91 on: June 08, 2008, 00:18:31 am »
 ;D NO ADDITIVES  ;D
 ;D Straight tap h2o !!  ;D
674 ml/min or 89 sec/L
10.2 Amps
18.9 VDC
192.78 watts
3.496ml/min/watt
50.47 percent Faraday
4.5 VDC at 1 Amp to the rotor
Learning every day
Spike
P.S.  Does anyone have a 110 V 1hp 3400rpm motor for sale, Or a reasonable source.  This was pretty hard on my small motor
Re: Spikes Cell
« Reply #92 on: June 08, 2008, 00:38:33 am »
harbor freight has them
Re: Spikes Cell
« Reply #93 on: June 08, 2008, 00:55:36 am »
Tractor Supply also has them pretty cheap.  You can get a 2 hp 115V/230V  - 3450rpm for $139.00
  • OO-Rah!
Re: Spikes Cell
« Reply #94 on: June 08, 2008, 01:11:06 am »
I see the one from Harbor Frieght for $139.99 plus shipping =$157.00
The one from Tractor Supply looks good, But I didn't see the speed, I have a tractor Supply 10 miles up the road. I'm going to check  ;D
Spike
hydro
Re: Spikes Cell
« Reply #95 on: June 08, 2008, 02:21:00 am »
very good job spike! thats the best production i've heard without additives! pat yourself on the back!
Do you feel you could have done this without the alternator spike?
