Author Topic: We are the Peace! Gift for the Humanity: Stanley Meyer Water Injector Principle!  (Read 11989 times)
Sebosfato,
If I appear to be thankless to you perhaps it's because I don't fall for your pitch for donations that I see in so many places.  It must be working as you continue to invest time in your endeavor and as Barnum said "there's a sucker born every minute".  I choose not to donate.  The videos I've seen of yours are unimpressive.  Yes I know how electric motors and generators work.  What of it and what does it have to do with this thread?
As an American I support your right to free speech and am as well exercising my freedom of expression.  Perhaps you are the one who is thankless.  I fail to see how or why you are entitled to anyone's hard earned money.  Until you have a working prototype or proof of concept this thread is a work of fiction.  If you feel you have a working hypothesis (educated guess) then it is worthy of the experimental method and a conclusion true or false.  So get on with it or more likely come up with another working hypothesis and ask for more donations.  I am seeing a pattern...
Regards,
Andy
Hi Donald,
I provided an explanation for the current restricting Meyer told us about, i provided a testing setup witch teached us all how resonance and recirculating currents really works and how to do the electrolysis at the lowest possible voltage, I provided an automatic calculation for air inductor, for the resonance itself with all calculations needed, i also provided a PLL design to drive the system at the exact resonant frequency. And a video on youtube witch talk about the principle.
Now I came up with the solution for the injector system witch is very much more economic viable and lighter than the theory i had before. So as its already in the public domain because myers patent and others are older than 20 years i decided to release all his info here because i was having problems releasing my own patented technology, the army didn't allowed us if we release it we go to the jail. So here it is the info about meyer tech, how it worked and soon more instructions on how to produce it. Thats all i have and i believe is huge!
If you didn't understood yet the technology please take the time to read it all again. Its very clear. Sorry if maybe my english is not perfect, i learned it alone.
I'm not going against the documents meyer provided, He told us he were using compressing pumps, he even told us the size of the holes that he was using. Even the amount of water per injection. It were very clear that you just need to know the speed water will take ... Please read it all again i'm sure you will understand and i'm sure you will want help us with answers for some technical questions like the pressure one and maybe even more if you want...
I'm not wanting to mass product it myself anymore i just want to finish the project for now and provide the answer for the humanity! I'm tired of investors they just want to make you feel bad and want to be aways richer they don't care about the earth and less yet about who you are and what you believe...
Hi Andy,
If you know how a generator works you may read again and think well, because the principle is quite the same. (conductor crossing an magnetic field)
For your info since i asked for donations for the 1° time i got only 250 euros witch became test setups and knowledge. I also had to work for live but i already invested about 20 thousand euros in time, rent, equipments and test setups in the last 4 years dedicated only to this. Donations would help a lot because recently i'm not working but i have people around me helping me, so my time is free now and still working and studying 24h on this.
Best Regards
Fabio
Andy,
As a moderator i could just simply ignore and delete anything i consider offensive however i won't do this just to prove i'm telling you the true...
So here a contest If you understand this principle,  i ask you to delete you last two posts, what do you think about?
Regards ;)
I've read over your theories regarding the Water Fuel Cell technology and you are not correct. I have spend countless hours reviewing all the videos, patents, pictures, and details from Stan's work and you simply are not on track.
I suggest for you to read this thread again once more and again than so you have a chance to understand. I clearly explained here how the injectors work. I showed the calculation of the water speed and how much voltage will be generated because of its speed crossing magnetic fields induced by voltage fields. Open your mind. I'm talking about physics not what meyer talked to confuse us.
I also spent countless hours reading and watching all about Stan. He wouldn't explain this EHD thing because is the secret of his patents! You can learn about this only if you are studying to be doctor in physics.
http://en.wikipedia.org/wiki/Plasma_physics
http://en.wikipedia.org/wiki/Maxwell%27s_equations
http://en.wikipedia.org/wiki/Electrophoresis
http://en.wikipedia.org/wiki/Electrokinetic_phenomena
http://en.wikipedia.org/wiki/Streaming_potential
http://en.wikipedia.org/wiki/Electrospray
http://en.wikipedia.org/wiki/Electrohydrodynamics
http://en.wikipedia.org/wiki/Pressure
The voltage alone wont do any work. Voltage together with movement can do work.
Example:
You have a parallel plate air capacitor charged with 100volts and than disconnected from the power supply.
What happen when you pull the plates apart?
Wouldn't the voltage raise while the charge remains the same?
Why the voltage raised?
because you did work separating the plates!
This is the principle of the Wimshurst generator.
If the power supply were still connected when you separate the plates the voltage would remain the same and the charge would reduce.
Sebosfato,
You consider my posts offensive?  Sorry didn't know you were so sensitive.  Any PhD candidate would go through the same process of critical analysis that this thread is going through before achieving the degree.  I will not delete my posts.  That fact that you brought it up does not indicate you to be a free thinker.  It suggests something else.  Since you haven't even begun to build the prototype you haven't considered factors of erosion on your 0.4 mm nozzle or what might happen if it were clogged.  Belief without evidence is faith not science.
Regards,
Andy
You can delete or not it's not my problem, its just worst for those who will read your comments witch are not related with the technology.
If proper filtering is provided i believe it wont get clogged, of course i'm still working on the design and the durability of the hole is not yet possible to predict even if thinking about it should last for a very long time for how i imagine it about 1/2 cm long. But is very clear to me and others that meyer did this way and that is one of the only ways to do it in a manner witch is economically viable, of easy installation and light weight. However if you are  a bit jealous for not being the one who discovered the process, you can be part of this discover by helping to find out the pressure we need to maintain on the tank for it to work... be part of the team so you and human race will only benefit from this  kind of behavior (partnership).   I don't want to be proud to have get there alone. I don't really care about this, i just want to see water cars and airplanes buses and camions running in the streets.
I'm not here to prove i'm a free thinker i just believe to be a thinker that have many solutions for todays problems.
Do you remember dynodon's video where he show the injector?
Meyer did so
Yes we Can!
Evidences are the hundreds of patents claiming free energy devices, Stan's videos, coincidences that happened with me along my way. Than physics books, and logic... Read it again and you will see the logic!
Pressure (potential energy) can do work.
I'm also studying about diamagnetic materials witch converts magnetic fields because maybe they are needed inside the injector... many things to consider...
Regards
I will not delete as I have said before my posts are for the benefit of others who have a choice to donate or not.  I'm glad I was helpful in your thinking thru what you propose (as that is all it is at this point) and I am not jealous because it was first proposed by Stan Meyer not you or I.  There is already someone who claims to have a working water fuel injector  system running and is currently in the process of marketing and I wish him well.  It should hit the news shortly.  I respectfully decline your invitation to join your team thanks anyway.  And I've already seen a water car in action.  Daniel Dingel is alive and well and free and working still as of this past January contrary to reports by the media.  But don't take my word for it find out for yourself.
Regards,
Andy
