Hi CrazyEwok,
Thank you For your analysis i will answer you in points:
1- I'm not sure yet, however i think that for the conductivity meyer used the ionized gases.
2- Yes you are right is like a simple electrolysis. I guess the ionized gazed for being conductive will work as electrolyte or something like that...
3- The electrodes will not last forever however i believe will last enough to be economically viable, and they will have a separation of maybe 1 or 2 mm thus i believe also that the deposits will not be a such a problem if we use ionized gas and deionized water to run.
4- The links to wiki is one of the materials that took my attention, i don't believe that this links would take my credibility under than i have follow the MIT's open courses in physics and some chemistry. However i'm studying about electronics and hydrogen, electrolysis, sm and everything related since almost 4 years.
5- here you are talking about the HYPER DRIVE witch also used a similar principle. But instead of generating electricity and breaking up the water only it concentrated in give thrusting to the boats. Look for EHD THrUSTER
6- Yes we will have some losses but won't be greater than the gain in energy that we can have. look closely at the calculation i showed you will understand i'm sure.
7- Yes amperage is huge but if we consider that we have water cooling, we can push up to 10 or 15 amperes per mm2. We use coper bars not wire. For the injector i want to try many things different in the try to reduce costs and weight. Just to let you know last device (electrolyzer) witch i can't talk about weighted 140 pounds without water tank.
8- I believe this is the only theory in the world witch holds. I tried everything believe me. Is not a case that you learn it only if you are a doctor, NASA use this already i'm almost sure.
9- I never saw this V series end, i heard the message and were cool and so i used, i'm not an alien and i don't want to eat nobody believe me i'm vegetarian since i was born
10- What can make it ou is to put together the resonance, and nice materials, i told you almost all i discovered about the injector believe me. For sure i want to build it in different sizes to be able to advance in the design to be able to design it to fit every needs.
I never built the injector and is new for me i'm studying 20 hours a day about it on books and i'm going to talk with doctors in physics here to try to find some help...
Thank you very much for posting this is the level i would like to maintain here!
Best Regards
