Author Topic: We are the Peace! Gift for the Humanity: Stanley Meyer Water Injector Principle!  (Read 11990 times)
 ;D It's a funny way to know what people are thinking!  ;)
  • Yes I got Jolted,
Hi Sebosfato... there is some merit on your thoughts only tests will prove if it will work or not.
Oh yeah, don't mind the Forum entertainer aka Dankie.
Jolt
Thank you jolt,  ;)
i would like to make you all notice what i found as a comment on the mhd power generation link on youtube i added before:
"sdfab Youre a genius sir!! my hat is off to you...... I thought of the same idea but using hydrogen and oxygen gas created from water which is subjected to a magnetic feild which ionizes and charge seperates the gas making it conductive then further electromagnets on the gas ring accelerate the conductive plasma past our collector windings this increases the strength of our hydrogen after its electron? removal plus the power generation... amazing work my freind "
Sounds something like what we want...
Oh boy
i think i got it
To ionize and destabilize oxygen we need a load witch will consume the electrons from the air gases.
What?
Yes, picture that we are generating electricity by moving the air inside a electric field so where will the electrons come from to form the current? from the gas ...
Ionizer probably solved
Thats why meyer said he used the electron extraction circuit with a heater resistance as a load. Think about!
 :P ;D
  • Yes I got Jolted,
Ok, I did some reading about MHD generator and there are some bad news, this method of generating electric current is very inefficient, but if this method could be added to the electrolysis process then it would make the electrolysis a little more efficient.
Hi jolt i read few times that EHD and MHD can reach almost 100% efficiency in the propulsion operation if designed well thus i guess inverting the use of the Lorentz forces we can actually generate with very high efficiency. I read about this in few time ago so i don't remember the document but i'm trying to find it again. If i remember well The % is only limited by the resistance to the flow of the liquid on the walls of the system and copper losses. Being water cut by the magnetic fields at high speed the water should just fall apart when it becomes gas it should also expand by a factor or 1800 so should even increase the speed second my thoughts. Anyway if we can accelerate the water enough i believe the efficiency here will not be that important. We are going to use also the principle of the recirculation of the current so i still believe it will still work in the end. My best guess or the most positive vibration one is that meyer used only Stainless steel on the injector, this would make our life's much easier and economical. Who could help us i think is dynodon who have seeing the injectors thru his own hands. Hope he can help us with any guessing.
Good night for you all
see you tomorrow
sebosfato, there is one major flaw to your reasoning. When current flows, voltage drops and our friend Lenz once again rears it's ugly head. How does Lenz affect a particle accelerator?
Hi bubz
Lenz force is the the force that a magnetic field exerts in any conducting media against its movement, (simple example if you have a aluminum heat sync and a strong magnet and try to approximate one in relation to the other you will see there will be a force acting, but after some micro seconds it will touch the heat sync) This is because the magnetic field is inducing a current in the heat sync witch generates a counter electro motive force. Thus Lenz forces caused by permanent magnets can actually acts as a break to a moving conductor, but physics tells us something must happen thus an electric current is induced in this conductor or voltage or whatever one wants to call it like.
 In a particle accelerator depending on the type they use a variant magnetic field for accelerating the particles if i remember well (coils) The act like a electromagnetic pump in sync with the movement of the particle. and also magnets in a certain configuration  to contain the particles in the middle of the tube to avoid contact with the tube walls. They also use electric fields to accelerate the particles. I showed once here in the forum link for a ping pong boll demo video on you tube between two plates and in a circular accelerating configuration.
In our case to lower costs we don't want to use magnets we only are using the voltage to create an initial current, this current will create a small magnetic field, than we are going to make water + ionized gases to cross this electric field at very high speed 100km/h thus this movement will induce a further increasing voltage and a current and thus a magnetic field and so on that will pull the molecules apart by electrolysis. imagine the magnetic field will work like a knife that will just cut the water.
I remember you the work is done by the pressure that forces the water to flow. There will be a resonance there like voltage induce a current, current induce a magnetic field, water induce a voltage this voltage induce a current, this current increase the magnetic field and so on,
I believe that in the end of the injector water is going to be expelled as a GAS probably with few droplets of water together.
I will start doing some tests with somethings i have here, like a high pressure machine to clean cars, some magnets, voltmeter...
Regards
