Author Topic: We are the Peace! Gift for the Humanity: Stanley Meyer Water Injector Principle!  (Read 11989 times)
I had an idea about the gas processor,
he used lasers right?
i was studying about plasma and drop into laser cooling, they say that 1 mili Kelvin temperatures can be reached  if i understood well...
Superconductivity happens when we have the atoms freeze so their electrons are kind of free to be allowed to move.
he also talked about slowing down the electron velocity.. and said that voltage would do this .... well just an idea
What if he was using the lasers to supercool some of the atoms releasing this way the electrons ?
What do you think about guys?
sebos
This idea is not what Stan Meyer was doing.
First, he used LED's as distraction. He did this, because he loved LED's.
The theory's behind it are nice, but no way it works in a way that you or I see any notice.
Just my 0,02
Fabio,
Maybe you aked the wrong question towards your professor.
When i turn up my ionizer, i feel the electron wind.
Its like a fan without moving parts!
So, yes. Electrons are moving in an ionizer.
Secondly, you had to inform your professor about the fact that these electrons are bonding with Oxygen which comes from an electrolysis proces.
These Oxygen atoms are missing electrons because of the electrolysis proces and they all want to get into a stable state by ripping or stealing electrons from their environment.
Thats what i notice in my tests here. I clearly see and hear such a change in my engine when i turn up the ionizers.
As soon as my Big Beast waterfuelcell is ready i wanna go to a garage to measure the exhaust gasses from my car when it runs on HHO only.
This with and without ionizer.
See what kind of reports i'll get then..
  • Yes I got Jolted,
Hey Steve,
I think what the professor meant was to ionize air to the point it become conductive so it could be used on a MHD Gen, it would need a lot of heat.
Hey Steve,
Aha, ok Jolt.  ;)
Hi steve
In the electrolysis process the oxygen that goes out is stabilized there is no missing electrons.  The oxygen when is in the form of water molecule shares 2 electrons with the hydrogen atoms, thus there are 10 electrons in the molecule, when you apply the voltage it induce a flow of electrons witch will split the water by oxidation and reduction reactions witch will gain and lose electrons, but actually in the end oxygen goes out with 8 electrons and hydrogen with 1 electron each atom.
The doc said to me that the plasma or when you have ionization you will end up with an ion witch in this case lets take oxygen and free electrons, but he said that they remain there all together if it's really hot, if it's not it will recombine to stabilize immediately.
To achieve plasmas with lower temperature they use cesium or sodium vapor ( like in the vacuum vapor lamps) because they have a lower work function witch allows this atoms to free electrons or to become ionized at lower temperatures or smaller energy. Lithium also have a low work function. than they use this initial conductivity to push thru it the huge current witch heat up the atoms of the gas making it to become ionized.
About the stan assumption of consuming electrons i don't really know, because electrons are electrons and can't become photons or anything else, and they will always be there because being a negative charge and having the atom become positively charged they attract. At least that was what the doctor said.
"If you could put a coulomb of electrons inside a box and one coulomb of ions in another box and let them be 1 meter far from each other the attraction force will be =  to the attraction the sun have in relation to the earth or something like that. "
Yes i know this fan behavior of the ionizer it smells ozone also, is the principle behind ion thrusters called also ehd thrusters ...
Did the ionization you are doing helped in someway the engine performance?
Best Regards
Sebosfato,
You should investigate the Tesla hairpin circuit and light some lightbulbs in water and ask your professor to explain that.  Or try to explain that for yourself.
Regards,
Andy
Hi steve
Best Regards
The engine gave a very noticeable reaction.
Because i do not have a dyno, i must go on revvs and sound.
The engine ran much better and max revvs went up as well.
Like 30% gain.
well very nice,
Did you tried to raise the voltage of the ionizer, or to raise the surface area of the ionizer? is the energy for the ionizer coming from the battery? You tried on the bike right? How much energy you're consuming to drive the ionizer steve? This is very good news. We now need to understand what is really happening.
Thanks steve for all this!
Hi Andy i don't know this harping circuit i tried to google it but didn't found much clear info about it. Did you tried something?
Best Regards
Fabio
