Author Topic: Secret technology, Tesla stan  (Read 8431 times)
Re: Secret technology, Tesla stan
« Reply #64 on: May 17, 2019, 21:41:11 pm »
Yes, all you need is any transister. Try different voltages after you master it.
« Reply #65 on: May 18, 2019, 05:22:45 am »
what are you sleeping? look, I think you can use a small PNP transistor, I havent tried it but the only reason I see it wouldn't work is if the Base got zapped by the static feedback coil, it very well may work with distilled water! I'm almost sure it will!
« Reply #66 on: May 18, 2019, 08:01:49 am »
Man, the baby didnt like to go sleep...
I am soo tired.
You said that you got this circuit working?
  • Build it. Power it. Use it.
« Reply #67 on: May 18, 2019, 13:23:17 pm »
I will end this post with a generic wchematix that proves the claim. Power any coreless coil of around 20 to 30 ohms, using a diode charge a capacitor,s let the cell connect at one pole and mm arc at the other, around 2000hz tou can see this effect, you will see large cleAn bubbles. Let this lead you to the vacuum tube and higher power, not just for the fuel cell but for many other things ...
Where's the spark gap, then?  And is the capacitance intrinsic to the 'air core' TV choke? Or the transformer?  And the cell requires only a momentary bias from a car battery?  Is this the same circuit?
« Reply #68 on: May 18, 2019, 15:05:09 pm »
The answer to the problem is Tesla, he used a glass vacuum triod or the like. Easy to Homebrew And a very high powerful switch that can hit frequencies in the millions. Coil at these frequencies become capacitors. I have first handely built such a circuit that will dissosociate extremely insulated none conductive distilled water that proves this technology to work. But it's not just about the fuelcell. This frequency also is why the Hutchison can do things you can't comprehend. His devices operate with glowing vacuum resonaters like those Tesla used.
I like the way your cell jumps when you first turn it on.  But what Hutchinson has isn't Anti-.  It's actually A-grav, the absence, due to a shielding effect.  His video does show a field shape defining electrode.  Put that on the opposite side of your cell and see what happens.
P.S.  John did ask to join my network at LinkedIn, and I appreciate all of my friends who are watching from a distance.
edit:  Disclosure is based on a need to know.  "Knock and it shall be opened unto you."
« Last Edit: May 18, 2019, 16:23:39 pm by tektrical »
« Reply #69 on: May 18, 2019, 17:50:34 pm »
I am soo tired.
Sorry I know that feeling all to well!!! I now have to get permission to play lol!!!
« Reply #70 on: May 18, 2019, 17:51:40 pm »
The last post sir doesn't have a spark gap, it is exactly as drawn.
« Reply #71 on: May 18, 2019, 17:53:20 pm »
You tested the circuit?
