Author Topic: FULL ATTENTION TO ALL MEMBERS - MUST READ  (Read 4470 times)
Re: FULL ATTENTION TO ALL MEMBERS - MUST READ
« Reply #16 on: October 05, 2019, 19:17:04 pm »
If this is the attitude you guys are going to have, I simply will not update you anymore. I'm sorry you don't understand it. Stevie, we can continue this manger if you like, I am working on breaking down these formulas atm. My parts list has been filled and on the way. And by the way, I measured over 1 thousand volts across my cavity last night. You guys are unbelievable, I suggest reconsidering. I haven't shared 2hat Stan was doing with the gas either. That's another day.
Brian,
I know that people doesnt understand the proces you are in.
But for what it is worth, i still stand with what i told you when we started this forum.
So, lets finish this technology of Meyer for once and for all.
« Reply #17 on: October 05, 2019, 19:23:15 pm »
Great work Brian,
The way I see it we can all benefit from the opinions and research of others, no need to put anyone down.
Perhaps he just realized something he didn't notice before, we've all been there...
Anyways, the thing I am wondering Brian is what are you seeing that others aren't?
Many of us have spent thousands of hours testing, troubleshooting, and tuning and have yet to hit resonance.
Stan states it is a simple series LC resonance, but if it really were just a series LC resonant circuit we would all have had it working years ago.
What are we missing here?
« Reply #18 on: October 05, 2019, 20:05:34 pm »
For some reason, I am seeing everything in stans work, and I am missing nothing. I dont know why.
Adriank, Have you used the Resistance Wire for the secondary, 36 awg, and chokes, 24 awg? Have you used the formulas in the work to confirm your circuit was in tune?
Did you isolate your ground? The Positive Pulse Attracts the oxygen water molecules electrons when the Voltage Field undergoes the Voltage step process, and the negative zone pushes it away. the Negative zone attracts the Positive Hydrogen proton. The Water Molecule has a equal charge, a  Zero Net Charge.
It is not until the Exciter arrays are stimulated with the voltage process, and exposed to the Polarization process you will see this effect. The water molecule has to first Elongate caused by the (Pulse Train) in a step charging effect by use of the Transfonner stan calles the Voltage intensifier Circuit. It is only then the Molecule reaches a Critical State and the VIC causes a electron Depletion switching off the covalent bond. Furthermore, The Electron extraction Process Destroys the electron making it impossible for the hydrogen and oxygen atoms to recombine.
The Isolated Ground (J) Causes the Positive pulse from (C) which is a (frequency Modulator) to give Exiter arrary E1 a positive electrical Fiel so great it pulls away the negative electron from the water molecule. Without (J) this would not happen. This VIC is a Voltage (Progression) DEFLECTION  Process.
(electronics)
The voltage applied between a pair of deflection electrodes to produce an electric field.
https://encyclopedia2.thefreedictionary.com/deflection+voltage#targetText=deflection%20voltage,to%20produce%20an%20electric%20field.
https://www.google.com/search?ei=ONuYXdrFAsv8tAXxm4TIBg&q=define+progressive+&oq=define+progressive+&gs_l=psy-ab.3..0l10.19945.21084..21891...0.2..0.118.650.5j2......0....1..gws-wiz.......0i71j33i160j33i10j0i22i30.SKwSqVyWhmo&ved=0ahUKEwjawY-42oXlAhVLPq0KHfENAWkQ4dUDCAs&uact=5 (Pulse Train)
« Reply #19 on: October 05, 2019, 20:20:06 pm »
Quick Examples https://duckduckgo.com/?q=air+ionizer+deflection+circuit&t=h_&iax=images&ia=images&iai=https%3A%2F%2Fimages-na.ssl-images-amazon.com%2Fimages%2FI%2F41jsmYkmHuL.jpg
https://duckduckgo.com/?q=air+ionizer+deflection+circuit&t=h_&iax=images&ia=images&iai=http%3A%2F%2Fwww.seekic.com%2Fuploadfile%2Fic-circuit%2F201357214617346.jpg
(C) is a Modulator in Figure 1.1 Once Positive Volatage Field Goes High, Blocking Diode (B) Only allows voltage to flow in one direction, Positive Voltage Field is Conneected threw Isolated ground (J) Causing a step charging Voltage Field across Exciter Arrarys ER1 and ER2 which causes the voltage deplection process. (Polarization Process)
« Reply #20 on: October 05, 2019, 20:26:05 pm »
about deflecting, its in Stans work clear that he applied a negative and positive puls to the electrodes.
Not a ground and a positive pulse.
A negative and a positive pulse. Coming out of the bifilar coil of the vic.
He needed strait dc electrolsys , i think as a start pulse, followed by the pulse from the bifcoil.
The voltage across the cell is zero, but thats because both sides compensate.
However, compared to neutral .....
I think that is what he ment by using acceleration.
https://www.falstad.com/circuit/
$ 1 0.000005 4.078577355933338 50 5 50
T 112 160 192 208 0 4 1 -0.00006420120755636316 9.402065827586223e-20 0.999
T 432 160 368 112 0 4 1 0.0000642012075563528 -2.2022832859098747e-20 0.999
v 432 160 432 208 0 1 40 5 0 3.141592653589793 0.5
v 112 160 112 208 0 1 40 5 0 0 0.5
d 192 160 240 112 2 default
p 240 112 240 208 1 0
p 320 112 304 208 1 0
w 288 208 304 208 0
w 240 208 256 208 0
w 192 208 240 208 0
w 368 208 304 208 0
w 256 208 288 208 0
d 368 160 320 112 2 default
o 6 64 0 4098 5 0.1 0 1
o 5 64 0 4098 5 0.1 0 1
« Last Edit: October 05, 2019, 21:35:23 pm by Steve »
« Reply #21 on: October 05, 2019, 20:43:16 pm »
I think I can insert a LC resonate Circuit Threw the AIR on the Positive Exciter Array, and do the Same on the Negative, I think I can Make A Wireless System to incorporate into Stans Hydrogen Fracturing Process.
You ask, what is new? Why am I just now coming forward ( Its because I just started To see what was going on)
I think their was a Block preventing me from seeing how it worked, it was recently, (Unblocked) from my brain. I see everything, Before I was Blind and could not see. Stans Instructions is Clearly there, Step By Step, Very Detailed instructions. It is all there! And it all makes perfect since. I do not think this technology stops at the water molecule, I think it goes much further, even to propel spacecraft from the ground up threw space without the use of water. I think the electron Deflection process can be used on much more than just water. It all dates back to around 1940s
This type of Voltage field generating apparatus is not used in todays generation. I think We, Us here at this forum as a team may very well crack much more than just electrolysis on its head. I think electrolysis by voltage deflection is just the start of the new aircraft that is yet to come ( Lifters) understood and Step Charged using a progressive attack. I think John hutchesin tuned into allot of this. This must have been how telsa ray gun worked, ( Hydrogen Gas Gun ) (Aircraft Lift Gun) Healing of Cancer, etc, I think this technology will open the doors to much greater solutions. Once it is understood and used, I think its power will be great!
« Reply #22 on: October 05, 2019, 20:48:56 pm »
maybe was first time you read it? well we read it hundreds of times... end to end... whats new bro?
this is a mistypo transfonner?
nice circuits! compliments
you need to learn what a transfonner is, (dig a little deeper) Yes, its old, very old! No, Stan did not mistype this at all, because I've researched it years, and yes it is a Transfonner. It is a Secondary inductor attatched to a secondary circuit to allow a large range of Frequencies. It is a Voltage Deflection circuit for Exictor Arrays, (Dig) Stan was no Green thumb, He obviously knew his stuff! He was indeed a math matticion  just as great as Nikolai Tesla.
« Reply #23 on: October 05, 2019, 22:03:53 pm »
I have had issues, With Low Viberations, I have had problems with entities.
I will break down this in my forum name under hydrcars, I will slowly do this, Sorry for snapping, But, I have been having issues lately, I've been sick. I've been dizzy.
This technology was used by tesla, and stan used it. I will start with the basics that even I myself Missed. Please Continue this under my forum category Hydrocars. I will have a post for each and every important part of this system which makes up its body. I do need help for thost that wishes to participate.
Also, for what its worth, I have already read over 1 thousand volts across the Exciter arrays. Also, Stan say 20 Thousand volts could be seen. Also, Sorry for the snapping. Hopefully if you follow my work, you want get sick to!
Also, I will be Continuing stans work as he left it off. I have not seen anyone even come close, even stan said even scientist fell flat on their face! I can see why!
Now I know The SCR was used for the EEC. I've seen stans pattern, I never knew he was this smart. Stan started out seperating the gas.
The Earliest steps, was, Stans AirIator was Invented Before the VIC was. The AirIator was A Gas Mixing Chamber. I will start another thread on that later, It is not important when 'l;daf;lkjas;f, Theres 2 things going on here, 1, producing HHO with no current flow, 2 Understanding that 1 gallon of water is equal to 2.5 Million Barrels of oil. You did not need the amount of hho you was producing to run that motercycle stevie, you had way more than you thought you needed. I will address this with you at a later time.
Yes you all have had this information, Yes, you all overlooked it. Including myself.
I understand you bro, life is crazy and it sometimes makes us blind and sometimes good or bad.. i highly suggest for you if you already dont know it to take nitazoxanida this is a medicine to kill intestinal worms,.,, i have had this crazy worms for years and it was holding my energy and my will too. My doctor prescribed that everyone should take it at least once a year! to control their population inside of us!
I know how is it like to understand it clearly! keep going we are here to support you!
I never tried running engines on hho i will do it soon with my new cell i think it will have enough hydrogen to get started.   hopefully =D
