Author Topic: FULL ATTENTION TO ALL MEMBERS - MUST READ  (Read 4465 times)
Re: FULL ATTENTION TO ALL MEMBERS - MUST READ
« Reply #32 on: October 06, 2019, 22:56:26 pm »
Was it Resistance Wire? if not try using Resistors for Laughs.
« Reply #33 on: October 06, 2019, 23:32:25 pm »
Its normal copperwire.
Stan said that it didnt matter.
He filed patents with resistance wire and with normal copperwire just to prevent other people copying and modifing his patent and make one their own.
« Reply #34 on: October 07, 2019, 01:42:42 am »
the only thing the resistive wire does is that it become the load.. i tried with some nickel chrome wire when you connect the load the voltage drops inside the coil...
if your cell has 1 ohm for example and you have 99 ohm coil and you apply 100v to it it will have 1 v on the cell or so
« Reply #35 on: October 07, 2019, 01:48:00 am »
thanks for some new insights into the technology.......
« Reply #36 on: February 17, 2021, 18:51:51 pm »
except if the capacitance is caused by the copper electron bounce on out side of wire
and changes which stainless
some thing that is not immediately obvious unless re making the exact round  transformer vic design by Meyers
