Author Topic: FULL ATTENTION TO ALL MEMBERS - MUST READ  (Read 4503 times)
Re: FULL ATTENTION TO ALL MEMBERS - MUST READ
« Reply #24 on: October 05, 2019, 22:05:50 pm »
maybe was first time you read it? well we read it hundreds of times... end to end... whats new bro?
this is a mistypo transfonner?
nice circuits! compliments
you need to learn what a transfonner is, (dig a little deeper) Yes, its old, very old! No, Stan did not mistype this at all, because I've researched it years, and yes it is a Transfonner. It is a Secondary inductor attatched to a secondary circuit to allow a large range of Frequencies. It is a Voltage Deflection circuit for Exictor Arrays, (Dig) Stan was no Green thumb, He obviously knew his stuff! He was indeed a math matticion  just as great as Nikolai Tesla.
i did a google on that word but i only found some books that were scanned and so it appeared to me that the scanner mistyped.. i will look further .. you have any source?
« Reply #25 on: October 05, 2019, 22:14:49 pm »
I have had issues, With Low Viberations, I have had problems with entities.
I will break down this in my forum name under hydrcars, I will slowly do this, Sorry for snapping, But, I have been having issues lately, I've been sick. I've been dizzy.
This technology was used by tesla, and stan used it. I will start with the basics that even I myself Missed. Please Continue this under my forum category Hydrocars. I will have a post for each and every important part of this system which makes up its body. I do need help for thost that wishes to participate.
Also, for what its worth, I have already read over 1 thousand volts across the Exciter arrays. Also, Stan say 20 Thousand volts could be seen. Also, Sorry for the snapping. Hopefully if you follow my work, you want get sick to!
Also, I will be Continuing stans work as he left it off. I have not seen anyone even come close, even stan said even scientist fell flat on their face! I can see why!
Now I know The SCR was used for the EEC. I've seen stans pattern, I never knew he was this smart. Stan started out seperating the gas.
The Earliest steps, was, Stans AirIator was Invented Before the VIC was. The AirIator was A Gas Mixing Chamber. I will start another thread on that later, It is not important when 'l;daf;lkjas;f, Theres 2 things going on here, 1, producing HHO with no current flow, 2 Understanding that 1 gallon of water is equal to 2.5 Million Barrels of oil. You did not need the amount of hho you was producing to run that motercycle stevie, you had way more than you thought you needed. I will address this with you at a later time.
Yes you all have had this information, Yes, you all overlooked it. Including myself.
I understand you bro, life is crazy and it sometimes makes us blind and sometimes good or bad.. i highly suggest for you if you already dont know it to take nitazoxanida this is a medicine to kill intestinal worms,.,, i have had this crazy worms for years and it was holding my energy and my will too. My doctor prescribed that everyone should take it at least once a year! to control their population inside of us!
I know how is it like to understand it clearly! keep going we are here to support you!
I never tried running engines on hho i will do it soon with my new cell i think it will have enough hydrogen to get started.   hopefully =D
I will attack you on this later, But for now, figure out how to seperate your hydrogen and oxygen, if you cant do that then re design your cell. Stan was doing this. Sorry for those that couldn't see it. I will prove this fact later! Till then, get it seperated. View the Airiator while you do this, the documents on it.
« Reply #26 on: October 05, 2019, 22:15:57 pm »
Yes, duckduck go, look for Tube type circuits, Look for what looks to be a VIC that has nothing to do with stan. Give me an hour and I will find you several similar circuits, Unfortanitly, I dont have the time today. I'm at a party.
« Reply #27 on: October 05, 2019, 22:20:07 pm »
For those that wants a promising but Flawed results with their fake chokes and un worthy copper coated wire do the following.
Attatch an antenna between your Diode and secondary transformer, alter freq, you will read Kilovolts.
That is only a fast example that will allow you to view high voltage directly across the cell. Important to know, Electrical Isolated Ground (J) should be adjacent from the diode. I just described a flawed methode to allow you to see a voltage across the fuel cell.
Also, 78 ohms, I used 2 inches tall with 1.5 Inch gap, 1.5 mm. More to come, Reasearch!
Find those Depflection Circuits, which is a Transfonner tuned to a Inductor. (VERY SORRY THIS INFORMATION IS GETTING LOST) and becoming obsolete.
Also, someone grab all of stans patens from the patents office website, I assume they will start to dissapear very quickly. Stevie, you do this. Post links to them here, upload them here before they are all gone. We need these here anyways. if you already have them, post the link here. SO that I can access them and further explain what he was doing to the gas.
« Reply #28 on: October 05, 2019, 22:28:14 pm »
This is my diode I received today.
« Reply #29 on: October 06, 2019, 10:34:07 am »
Dear Hydrocars,
If  you just look a bit futher then the lenght of your nose....
There is a whole chapter on Meyer in this forum.
http://www.ionizationx.com/index.php?board=195.0
If you think i missed out on a document, then please let me know.
« Reply #30 on: October 06, 2019, 17:30:52 pm »
Good deal Steve! My monkey boy is trying to break out if his baby jail, hard to do anything this day in time!
« Reply #31 on: October 06, 2019, 19:18:40 pm »
same here.
I have now two hours playtime.
btw, i found my little meyer toroid with copperwire on it.
