Author Topic: My Herman Anderson replication project  (Read 45952 times)
0 Members and 19 Guests are viewing this topic.
« Reply #88 on: February 03, 2017, 20:33:03 pm »
Where did it crack at ?
What are your goals with the cell?
It a tiny crack at the bottum, close by one seal and i didnt use enough liquid gasket on one electrode....
Goals? I want to see, or measure effects of the radiation of emf waves and magneticfields.
I will take gas samples and ignite them in front of cam etc etc
And i have a small genset to operate.....If the gas is trully deuterium, i should not have any problem operating it.
I had the genset running on HHO once. So i can compare.
cheers
Ten 4 on the genset .....how many HP is it? I'll get a similar engine :)
« Reply #89 on: February 03, 2017, 22:00:28 pm »
(I have trouble some times posting)
https://en.wikipedia.org/wiki/PH
pH is Hydrogen scale
« Reply #90 on: February 04, 2017, 09:54:27 am »
cheers
its a 800 watt genset..4 stroke
« Reply #91 on: February 04, 2017, 09:57:22 am »
I know when that happens. For whatever reasons posting an internet link results in a clean post without any text.....
« Reply #92 on: February 06, 2017, 12:32:20 pm »
The weekend was full of designing issues.
The Emf sparks high voltage circuit is , lets say, a work in progress. Or re design. Well, at least i didnt got fried.
Some other components went with a bang.. :(
  • Build it. Power it. Use it.
« Reply #93 on: February 06, 2017, 21:30:59 pm »
Well, it seems that nobody joins in here, except for Kevin and Fabio...
I repaired the cell for a second time, as it was still leaky.
Hope that it is now fine.
In the meanwhile i am playing with the electronics and High Voltage coils.
Today i seen violet colored sparks.......I think those a key.
The following days i will try again sparks, dc pulses, coils and what ever i come up with.
cheers
The violet colored sparks are likely due to a magnetic interrupter effect.  Otherwise, indicative of helium.  Deuterium would be reddish.
But good work so far; keep at it.
« Reply #94 on: February 08, 2017, 13:13:25 pm »
Thanks!
Well i will continue.
Here a small video of the newly hv generator sparks.
I am playing a bit with the sparkgap to see what that does.
cheers
https://youtu.be/39EWdY2ZrjU
« Reply #95 on: February 09, 2017, 07:16:41 am »
Where you able to make any determinations thus far?
