Author Topic: My Herman Anderson replication project  (Read 45942 times)
0 Members and 20 Guests are viewing this topic.
Sparkplug wire techno history
« Reply #104 on: February 14, 2017, 20:16:08 pm »
While spark plug wires may seem to be simple components, there is a reasonable amount of technology that goes into their design. This article will help consumers make informed choices while dispelling some common misconceptions.
    The basic function of a spark plug wire is to conduct spark energy from the ignition source, whether it be a distributor or coil pack, to the spark plugs. The more efficient the wire the more spark energy is transferred to the spark plug.
In The Beginning
    Probably the most efficient transfer of spark energy is made with solid core spark plug wire. This type of wire was extensively  used prior to the 60's before the introduction of car radios as standard equipment. A few modern day exceptions exist such as certain race applications and a few European car manufacturers. The problem with solid core wire is that it emits large amounts of RFI ( radio frequency interference) which affects radios, and onboard electronic systems in cars. When current passes through a wire, a magnetic field is formed. If the current flow is switched on and off rapidly as with an ignition system, RFI is caused by the magnetic field collapse (some refer to it as  EMF which stands for electromotive force). When manufacturers started installing radios in cars, a solution was needed to reduce the RFI. One of the first solutions was to mount resistors on the wire ends to reduce the current flow and consequently reduce the EMF and resultant RFI. The second solution, and the most popular by far, was to make the whole wire a resistor. Thus the age of carbon core wire (sometimes referred to as graphite core) was born. This type of wire needed a whole new type of construction over conventional solid core wire. Carbon core wire's basic construction starts with a non conductive structural member (nylon or Kevlar™) over which carbon fibers are deposited. These carbon fibers are typically blended  with latex or silicone  to form a flexible coating. A layer of EPDM rubber is then deposited over the core as primary insulation. Next a nylon bonding weave is placed over the wire which is followed by a final coating of either EPDM or silicone rubber. When new, this wire performs as designed. Over time however, with heat and vibration the carbon fibers tend to loosen which degrades conduction and eventually requires replacement. For this reason some OEMs (original equipment manufacturers) recommend replacement every 3 years or 60,000 KM. Carbon core wire is quite economical for manufacturers to use while suppressing sufficient RFI. This wire typically has a resistance of 3,000 to 20,000 ohms /ft. depending on the manufacturer.
O.K. So Where Do We Go Now ?
Previously mentioned, RFI is reduced by limiting the current flow in the wire. This reduction of current flow also results in a weaker spark to the plugs. An internal combustion engine operates on the principal of air and fuel burning in a cylinder and the expanding gases driving down the piston. That's right the fuel burns, not explodes as some believe. The hotter the spark in the cylinder the better the air/fuel ignition and better chance at complete combustion. We will come back to this in more detail later on, along with some common misconceptions. Since the hotter the spark the better combustion, an engine's efficiency improves, simple fact.  Carbon core wire is not our most efficient choice here, and solid core wire can't be used on modern vehicles. So where do we go from here ? The newest technology is wire wound construction which can go under many names such as magnetic suppression wire ( mag wire ), spiral core, helical core and so on. Although this type of wire is more costly than carbon core, vehicle manufacturers are using this type of wire more and more in newer vehicles for better efficiency and longer life.
So what is this "mag wire" wire all about ?
Let's begin with the basic construction of the wire, then get into some details that set brands apart from a performance and quality point of view. Mag wire begins with a non-conductive structural member such as nylon or Kevlar™ (just like carbon core wire). Over this member is wound a fine alloy wire in a spiral or helical fashion. The closer the turns are wound, the better the wire's quality and higher the production cost. Over this winding is deposited a choice of coatings, the lowest cost is again carbon in latex while the best and most expensive is ferrite (iron particles) suspended in a latex or silicone type coating. Covering this finished center conductor is either extruded EPDM or silicone rubber (much the same as carbon core wire). This wire's core performs a number of functions. First the spiral wound conductor conducts the spark energy efficiently and second it acts as a "choke" against the RFI. Thirdly it adds greater physical strength to the wire. The tighter the windings, the better the choke performs. The diameter of the center conductor is also of paramount importance, as the greater it's diameter becomes, again the better the choke's performance. The use of carbon latex coating further absorbs some RFI, however ferrite is vastly superior in noise suppression, however more expensive as previously mentioned.
There are many differing constructions of mag wire, some economical brands simply wind a fine wire around an existing carbon core wire center. Another economical method is to loose wind the conductor over a small center diameter to cut production costs. Almost anything goes just to call it mag wire.
To design a true mag wire and have it suppress RFI while transferring virtually unimpeded spark energy is no small task. Some manufacturers advertise very low resistances, which when conducting D.C. current (direct current) is good. However ignition systems also generate A.C. (alternating current) voltages which traverse the outer layer of the conductor and is less affected by resistance. For a mag wire to suppress RFI properly it needs a certain amount of resistance. Along with the afore mentioned spiral wound design and ferrite coating, we get a wire that now has inductive reactance which suppresses RFI. Inductance is a function of the spiral winding and is further enhanced by the ferrite which effectively multiplies it. Without further complexity,  the whole idea is to get a balance between conduction and RFI suppression.
Misconceptions
As touched on before, the hotter the spark the better the combustion. This process can be associated with a better transfer of the spark energy from it's source.  Misconception #1  " Any spark is adequate for combustion since it only needs to explode the fuel " -  not true. Fuel is meant to burn in a cylinder, not explode (fuel only explodes under such cases as pinging or detonation both of which are quite harmful to an engine). A weak spark may start the combustion process but since there is a finite amount of time for the mixture to burn prior to the exhaust valve opening, a better start of the combustion process will aid in a more complete burn. Misconception #2 " Hey, I heard too hot a spark burns holes in pistons ? "  -   NO ! . Improper fuel mixture and/or incorrect ignition timing can cause this, not a strong spark. By assuring a good spark reaches the cylinder, a proper burn of the fuel mixture can take place. Better energy transfer will also increase spark duration which is a function of current flow. The longer the spark is present, the larger the portion of the swirling mixture is ignited which allows more complete combustion. This inevitably gives you the most from the fuel entering the engine. Misconception #3 " If mag wire is so good wouldn't it come as standard factory equipment ? " Manufacturers have to balance performance and features against production costs. Most replaceable parts on a car can be found in a better quality or higher performance aftermarket version. Spark plug wires are no exception.
« Reply #105 on: February 19, 2017, 05:02:24 am »
Are you able to run your cell ?
« Reply #106 on: February 19, 2017, 13:40:24 pm »
Yes. The cell is very able to run.
« Reply #107 on: February 20, 2017, 11:42:03 am »
Hi folks,
I had to order (again) some parts for the high voltage setup which will take some days to arrive here. I am not happy with my current setup.
Till then, i will repair the cell leaks...
cheers
« Reply #108 on: February 20, 2017, 13:43:28 pm »
Kevin, have you ever seen this video?
I made it some years ago.
You see a magnetic field kicking hydrogen ions...
https://youtu.be/y--rfhMmCW8
« Reply #109 on: February 21, 2017, 12:39:54 pm »
No I haven't seen it before.There is a purpose of the magnetic field and a reason why you must know how strong it is and you have to understand how strong it has to be.There are a lot of ways you could look at it in terms of explaining why but the point is it does take a certain amount and a certain reason why.
« Last Edit: February 21, 2017, 13:52:44 pm by Newguy »
« Reply #110 on: February 22, 2017, 12:29:46 pm »
Cold cathode (Penning)[edit]
The Penning source is a low gas pressure, cold cathode ion source which utilizes crossed electric and magnetic fields. The ion source anode is at a positive potential, either dc or pulsed, with respect to the source cathode. The ion source voltage is normally between 2 and 7 kilovolts. A magnetic field, oriented parallel to the source axis, is produced by a permanent magnet. A plasma is formed along the axis of the anode which traps electrons which, in turn, ionize gas in the source. The ions are extracted through the exit cathode. Under normal operation, the ion species produced by the Penning source are over 90% molecular ions. This disadvantage is however compensated for by the other advantages of the system.
One of the cathodes is a cup made of soft iron, enclosing most of the discharge space. The bottom of the cup has a hole through which most of the generated ions are ejected by the magnetic field into the acceleration space. The soft iron shields the acceleration space from the magnetic field, to prevent a breakdown.[2]
Ions emerging from the exit cathode are accelerated through the potential difference between the exit cathode and the accelerator electrode. The schematic indicates that the exit cathode is at ground potential and the target is at high (negative) potential. This is the case in many sealed tube neutron generators. However, in cases when it is desired to deliver the maximum flux to a sample, it is desirable to operate the neutron tube with the target grounded and the source floating at high (positive) potential. The accelerator voltage is normally between 80 and 180 kilovolts.
The accelerating electrode has the shape of a long hollow cylinder. The ion beam has a slightly diverging angle (about 0.1 radian). The electrode shape and distance from target can be chosen so the entire target surface is bombarded with ions. Acceleration voltages of up to 200 kV are achievable.
The ions pass through the accelerating electrode and strike the target. When ions strike the target, 2–3 electrons per ion are produced by secondary emission. In order to prevent these secondary electrons from being accelerated back into the ion source, the accelerator electrode is biased negative with respect to the target. This voltage, called the suppressor voltage, must be at least 500 volts and may be as high as a few kilovolts. Loss of suppressor voltage will result in damage, possibly catastrophic, to the neutron tube.
Some neutron tubes incorporate an intermediate electrode, called the focus or extractor electrode, to control the size of the beam spot on the target. The gas pressure in the source is regulated by heating or cooling the gas reservoir element.
Radio frequency (RF)[edit]
Ions can be created by electrons formed in high-frequency electromagnetic field. The discharge is formed in a tube located between electrodes, or inside a coil. Over 90% proportion of atomic ions is achievable.[2]
« Reply #111 on: February 22, 2017, 17:28:55 pm »
The purpose of the magnetic field is to cause pression about the proton.... It aligns the spins of the protons(50%) and its when those spins are aligned (you could look at it as a polarization process with voltage in Stans case)they begin to precess.It's when (or just as or before...the process is so fast look at it how ever you need to) they precess are susceptible to other energies.
With water at 25°C the magnetic field required is 1826 gauss wich equates to a precession frequency of 7.6 megahurtz.....you are suppose to be a nuclear physicist to understand the rest so I'm not even attempting to try and explain .
