Author Topic: My Herman Anderson replication project  (Read 46014 times)
0 Members and 18 Guests are viewing this topic.
« Reply #80 on: January 25, 2017, 09:24:21 am »
About the 7.5 cps.
Take a look at the patent Herman referenced and see the ac square wave? That part of the waveform produces a discharge at each cycle of the HV ac portion of the waveform.The total square part of that waveform is what is pulsed at 7.5cps.
Here ya go....this is the patent Herman referenced and this is what Herman was talking about.
https://www.google.ch/patents/US4820957
Figure3 is what is required plain and simple.
To be more specific that wave form is wat the primary needs to see.The square part is the resonate or standing wave.Its much like Puharich and Stans waveforms.Its modulated at 7.5 cps.
Took me some minutes to understand that patent bla bla...
Here is what i think is written wrongly.
You see, if the minus of a dc powersource (battery) is hooked up to the engine and also one side of the secondairy coil is hooked up to the engine, you will never be able to create alternating currents.
What happens if the breaker points are closed is that current charges up the primary coil and also the secondairy coil gets a charge because of the changing magnetic field in the core.
When the breaker points disconnect, the primairy coil discharges into the capacitor that is hooked up over the breaker points. What then happens is a short time of resonance between the coil and the capacitor. Series LC resonance.
The patent calls it AC, which is wierd.
The output of the seconairy coil is hooked up to ground on 1 side and the otherside goes to sparkplug.
So, the waveform at the sparkplug should look like an AC waveform, but actually is positive ac wave form looking wave, as the totall wave never gets under zero volts....
Hope you understand. Otherwise just ask.
The first part of the patent is just a frequency converter changing DC into a ac pulse to feed the first transformer.
After the transformer a bridge rectifier changes the AC into pulsed DC....
cheers
« Reply #81 on: January 25, 2017, 15:29:19 pm »
what a day...
It seems that my cell was damaged after all.
The blast made some leaks and cracks.
I just spend hours trying to repair it...
no testing today
« Reply #82 on: January 27, 2017, 12:45:06 pm »
Update:
The cell is in working order again.
Working on some options for creating the needed magnetic field in the cell.
Herman stated that he had a positive magnetic field pushing the hydrogen ions really fast to the anode and vica versa the oxygen atoms supposed to pushed from the kathode by use of a negative magnetic field.
As i do not have soo much real laboratium equipment, i started to use my samsung mobile phone as indicator for gauss forces and magnetic field directions.
Well, i still hope that somebody has the full video of the Herman Interview for me....
Cheers
« Reply #83 on: January 29, 2017, 12:59:36 pm »
Help!
What does this mean in detail?
"pH 12 KOH deionized of ozonated water"
Anybody?
« Reply #84 on: February 03, 2017, 17:27:06 pm »
Well, it seems that nobody joins in here, except for Kevin and Fabio...
I repaired the cell for a second time, as it was still leaky.
Hope that it is now fine.
In the meanwhile i am playing with the electronics and High Voltage coils.
Today i seen violet colored sparks.......I think those a key.
The following days i will try again sparks, dc pulses, coils and what ever i come up with.
cheers
« Reply #85 on: February 03, 2017, 18:57:01 pm »
Where did it crack at ?
What are your goals with the cell?
« Reply #86 on: February 03, 2017, 19:47:04 pm »
It a tiny crack at the bottum, close by one seal and i didnt use enough liquid gasket on one electrode....
Goals? I want to see, or measure effects of the radiation of emf waves and magneticfields.
I will take gas samples and ignite them in front of cam etc etc
And i have a small genset to operate.....If the gas is trully deuterium, i should not have any problem operating it.
I had the genset running on HHO once. So i can compare.
cheers
« Reply #87 on: February 03, 2017, 19:48:48 pm »
More info from the Horvath patents:
Radiation sparkgaps are preferable 0.016 inch wide
More info:
Conventional Gap Settings Racing Plugs 0.016" 0.4mm
Heeeeeeee......that looks similar, is it.....
