Author Topic: My Herman Anderson replication project  (Read 46079 times)
« Reply #24 on: December 04, 2016, 17:06:59 pm »
Looks like a nice new experiment.
Fabio, maybe you should start your own project topic?
Now yours and my are a bit mixed.
What do you think?
cheers!
« Reply #25 on: December 04, 2016, 19:54:48 pm »
Of course bro! Will do it soon!! Sorry to get off topic I just wanted to help inspire some simple way of doing a good cell!
« Reply #26 on: December 09, 2016, 09:43:34 am »
today i received the polycabonate parts. All well cut.
They look great! Also the special welding glue is arrived.
Now its up to the fine sanding of the cut edges and then i am ready for the welding. Never done that before.
Happely i bought some extra pieces for test welds  :)
cheers
« Reply #27 on: December 09, 2016, 15:12:17 pm »
I use a syringe to apply the glue but when pieces are big I use to dip them into the liquid for a little while like when gluing tubes etc...  you will do it great!! Just put the pieces together and apply the glue there between and it will spread just like water would do so you can test with water to see if you are getting a good result before using the glue!!! Sometimes is not necessary to sand it much just clean and bang!
Cheers man
« Reply #28 on: December 09, 2016, 18:14:15 pm »
Thats the way  i do it, Fabio. The bond is so strong. Unbelievable.
Dichlormethane is what i use as glue. Its more a weld then glue.
Here the first piece is ready
https://youtu.be/gf3NRJjSutg
« Last Edit: December 09, 2016, 18:32:37 pm by Steve »
« Reply #29 on: December 10, 2016, 08:20:05 am »
That's cool Steve....are u putting the standing pipe apparatus on it?Just a reminder it's there to keep the water from getting to hot.
How should that look like?
« Reply #30 on: December 10, 2016, 16:47:07 pm »
its not really needed to prove the working of the cell, i think. It makes only sense if you want to use it in fulltime operation, is it?
« Reply #31 on: December 10, 2016, 19:33:41 pm »
Two questions
Is there a waterpump in there?
Is the standing pipe the gas outlet?
cheers
